Raven 1.8m Install Progress
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Found a side on diagram with dimensions that Ill be able to work from, Will attach if anyone finds it useful!
RimaNTSS
Some SAT-related hardware.
N-E from Riga
The problem with that diagram, as I see it, is fact that feed is not pointed symmetrical. It should be pointed several degrees lower. CM180diagram.jpg
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Oh very interesting! So both those angles you added should be equal?
None of the dimensions look right, it’s as though somebody has bought a batch of reflectors, and not thought enough about the associated metalwork that works as one with them.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
So it's time for the @RimaNTSS :) Channel Master measures picture, I guess!?!
Giving Topstring length and Bottomstring length, and G-spot.
As Raven = Channel Master, I believe? The 22.6 offset angle gave it away, for me.
greetz,
A33
Edit: Here, for instance: Channel Master 1.2m Dish - Page 3 - BATC - Forum
Being a Ka band compliant package, rounding off to the nearest mm is no longer good enough.
RimaNTSS
N-E from Riga
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Just read through that entire thread this morning, fascinating, so the question is I guess does the TX/RX arm have the same issues.
RimaNTSS
N-E from Riga
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Until I get the piece i need Im not sure how effective any measurements I take will help, I'll need to guess the angle as it is without it.
The measurements will (or should) be close to those John has already taken on the second attempt. From those you should be able to work out the optimum position of the feed assembly with an adjustable clamp.
RimaNTSS
N-E from Riga
Well, on the drawing (it also may be not drawing but just a picture) @mapperuo presented in post #62 we can only know for sure the A-B distance of the working area of the dish. I took this dimension as a ruler and made a overplayed all needed information in mm. We can see that original feedhorn is not pointed to the point G, and also phase center of the feedhorn is more than 10cm away from the focal point of the dish. CM180diagramTrue.jpg
Well, on the drawing (it also may be not drawing but just a picture) @mapperuo presented in post #62 we can only know for sure the A-B distance of the working area of the dish. I took this dimension as a ruler and made a overplayed all needed information in mm. We can see that original feedhorn is not pointed to the point G, and also phase center of the feedhorn is more than 10cm away from the focal point of the dish. View attachment 126381
I alluded to that earlier. Nothing 'looks' right in any of the online sites with the newer feed arrangement.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Well I've 3D modelled a part using measurements Ive taken from the dish, I really expect it to take 3 or 4 refinements and new prints to get a decent one.. But the 1st alpha version is printing as we speak.
Actually just posting this, I realise I've forgotten to put the holes in for the arms... So make that 4 or 5 refinements :p
As one of my favourite sayings goes - - 'where there's a will - there's a way' . Look forward to the printed version
What material are you printing it out with ?
It's at the focal point of the dish (or will be......)
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Not much of an update, crappy weather!
Have raided my photography box and essentially made a temporary version of RimaNTSS's device to try find the G Spot. About 1.5db off of my other Raven so still some tweaking to do.
