Listen Up Octagon SX88+
Did you try any other firmware version?
mikeisyou
Feed Hunter
England
No answer from Octagon - I suppose I have to return the SX88+ as I cant watch HD channels on it. Shame as its good on SD
Octagon are good at responding via Facebook Messenger
tallkeith
Octagon SX88+ 80cm dish Technomate motor
Hertfordshire UK
Not yet - but will have a try when I can download other versions.
Go to the forum search, then use keywords sx88+ firmware update, and then in the 'posted by' box put 'octagon-germany' :)
http://www.octagon-germany.eu/
Firmware (Software) Update V10529 01-11-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. TV Online added.
2. Update latest OS Version.
3. WiFi driver fix 7601 - WL048 + WL058.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10529.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10529.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10529'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ SE C/T2 & SE C/T2 WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. TV Online added.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
real shame most of your updates are IPTV related and no news about Intelsat 27.5ºW integration for example .. you have nice hardware but it will die soon in the market if you don't keep it up to date for what most wanted it for ..cheers
tallkeith
Hertfordshire UK
The latest firmware hasn't fixed the sound sync on Astra HD channels.
Rubbish
tallkeith
Hertfordshire UK
Chucked it in the bin.
I'll find something else that works.
pipino
Back from the dead
Rubbish
it's clearly software related problem and it seems they are more interested to push the sale of the 4K models with IPTV focus rather than fix these nasty issues ..real shame :(
Firmware (Software) Update V10531 29-11-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Default sort by number for Stalker - Option Button.
2. Add. User Agent for Stalker - Stalker Option - System.
3. Modified ATR of for Slovakia.
4. YouTube Improved.
a.) Installieren Sie die aktuelle Firmware v10531.
a.) Install the latest firmware v10531.
a.) En son yazılımı v10531'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10532 06-12-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
SX89
SX889
Changes:
1. Fixed sort by number for Stalker.
a.) Installieren Sie die aktuelle Firmware v10532.
a.) Install the latest firmware v10532.
a.) En son yazılımı v10532'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
SX89:
SX889:
Online güncelleyin!
Do you have a USB stick (with only a firmware file on it) connected when attempting the recovery? Make sure it's a different file to the one which caused the trouble, it may be corrupted.
Try an older firmware.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
The PROBLEM that is here is that when I do a reset, the display appears UPG, but it DOES NOT go to the USB part and then go search for the firmware!
He doesn't even move forward !!!
Unplug the power and remove all the connections, usb, coax, LAN,... Just leave the HDMI connected, then reconnect the power and try to hard reset without USB inserted.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
If that doesn't work, try it with a USB with 4gb storage maximum. The lower, the better. Make sure it is formated the correct way on your pc (try both FAT & NTFS) and redownload the old firmware from octagon, unzip on your pc and paste on the usb drive.
If you have done all this, I don't know what would work...
Try without the HDMI connected. If that makes no difference then wait for @Octagon-Germany to respond.
No heads-up from Octagon Germany as yet, but f/w version 1.05.35 (dated 31st Dec) now available to install online
Firmware (Software) Update V10535 02-01-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
SX89
SX889
Changes:
1. Fixed user agent wrong format.
2. Abertis fixed. 2 Decode Support.
3. Fixed long EPG name in EPG Menu.
a.) Installieren Sie die aktuelle Firmware v10535.
a.) Install the latest firmware v10535.
a.) En son yazılımı v10535'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
SX89:
SX889:
Online güncelleyin!
And when I just connect everything without doing rest, the static image with the logo and the message on the screen "SX88" is always there and it doesn't go any further!
Did you manage to fix this? @Octagon-Germany can you help? :)
