Newsnet on Ka Band A
18709V 3328 2/3. D-Day Anniversary Portsmouth.
Feed some way off the usual area, which is busy today.
.. A couple of nice TC's from 18GHz
18GHz TC's.... 19.2° East. - reduced...JPG18GHz TC's.... 19.2° East  .... Reduced..JPG18GHz TC's.... 19.2° East  . Army.. reduced.........JPG
Did you want to update Lyngsat Llew ?.
Late now, maybe tomorrow if it's not updated by then.
Certainly busy and interesting feeds today, May be as active tomorrow.
Back today on 18709V. This time across La Manche :)
Must be having a senior moment Llew...
.. How rude!.
Well i thought i'd dropped a proverbial testicle with the observation i had made and reported on 30 mins earlier so scrubbed the post- so i thought lol.
All it was, was that i noticed the marker at 18500 V or 504.7 ish to be more accurate, was missing so thought i would share the useless bit of information with my fellow fruit cakes.
The marker is now back up and running.
Here's my original graphic ...
18GHz Ka Vertical pol sigs on 19.2° E very busy tonight as expected - - no new Horizontal freq's seen as yet
Yup, as expected. I have one at 18578V too, but below lock here.
Yep, that freq is just a tad under lock with me as well Llew - there's about another three from that plot that is also under lock.
Ka conditions not too great with me tonight - i can see the levels fluctuating slightly in real time on the meter.
tony smith
80cms motorised mesh offset dish, ku band (Universal LNB)Technomate 5402, 1.8 Channel Master offset fixed K band lnb's 18.2-19.3, 19.2 -20.3, 1.1 Triax offset dish fixed
midlands UK
Hi 18.635 Ghz busy at the moment first ITN then much higher level for a regional news unit, I have been seeing a carrier not sure what it carrying at 18.795 Ghz all on Vert pol.
.... this plot just now of the usual Newsnet frequency span between the two outer beacon / telemetry markers - nothing apart from the unusually high level comms freq of 18.561 V.
tony smith
midlands UK
Of all the receivers I have owned and still do which is many, the Hellobox8 is the only one able to pick up the data stream close to Newsnet in a blind scan, or indeed in any other scan. I have no PC card but sure they would be able to pick it up..
The frequency is wrong as I cannot set the correct LOF in the receivers menu..P1010013.JPG
Very good scopus. Many PC cards using Crazyscan BS sweeping usually finds 10963V. An example is post #484.
The Newsnet ID seems to have changed to 'MK Spare'
The bit rate seems to have dropped significantly, now very blocky..Newsnet.jpg
The bit rate seems to have dropped significantly, now very blocky..View attachment 133596
I saw this also yesterday on the analyser - the signal dropped to nothing for a while and very slowly started to come back out of the noise but never got back up to it's usual strength
