Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
YES! exactly this!!! it looks like just you and me with this issue then! (which cannot be true)Because if you have multiple receivers it's extremely annoying if one remote controls more than one box. If this 'feature' can't be disabled then you couldn't have an sx88 & sf8008 on the go at the same time - both boxes would react simultaneously.
i noticed your point was totally "glossed over" (ignored)
maybe the only way to disable it, is to uninstall the driver (if its driver based) - but otherwise, we're stuck on a old firmware forever!
very annoying!
why did they think it would be useful (and to even go to the effort!!!) to introduce functionality which allows one remote to control more than one STB. Absolutely ridiculous
