Türksat-5a and new ku band??
seeing this at the moment , 13406 V beacon type of signal - pretty sure it's coming off the bird and not interference as i loose it when panning left or right / up or down. Will keep an eye on it.
Info: Gibertini 1.2 dish, 17Km north of the City of Nottingham, UK.
Now seeing testing signal levels at 13.428 GHz V.
Both carriers up .....
** Accuracy of signal D/L frequency not absolutely known at this stage from me - awaiting official satellite operator documentation for D/L frequencies.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
I can confirm 13428 V - earlier this morning on 1,2m (I was in linear horizontal at this time)...
Tests at this time: 11465 H, 11515 H, 11555 H, 11595 H, 11635 H, 11660 H
s-band
Essex
I missed 13428V. I thought I might see transponder noise but I could not.
There's about 1/2dB of excess ground noise at 24.1 elevation.
10967 H-test carrier and 11595 H- test carrier
dreamsat
germany
works here too
dx qwer
Rastatt/Germany
Sorry, a "deeper" look on my last attached scan centered frequency at 13416. :-doh
If i remember right, you had one of the metal cased more expensive variety of the single polarity extended Ku lnb's - just wondering what the LO is on yours..... on my cheaper version i'm sure it's 11800 but don't think it was accurately set as that at factory ?, so can't guarantee the absolute accuracy from the scans. All very interesting though , i also checked out 17E extended Ku a few times over the last couple of days but not seen any activity as yet in the 13.4 to 13.65 GHz range.
** 13.432 V is now showing as well
s-band
Essex
Full extended band scan (ignore the big signal at 13.650, its the fundamental of the synth at the IF)
Blue is live trace with the marker, magenta is the max held trace which has been running for the past couple of hours. The carrier on 13428MHz is varying in level and the marker shows the instantaneous value. The noise is only visible when the carrier is at maximum (TP max gain?)
dx qwer
Rastatt/Germany
I can see 13428 V active now (linear vertical scan on cheap plastic one, LO 11800)
/edit: This time I can see beacon 13401 V with poor signal.
This is nirvana time for the "wavy line men" on this extended Ku-Band.
I wonder how long it is before the "picture men" get a look in?
I better get that box of extended Ku-Band LNB's out of the loft and dust them off, there might be sales forthcoming?
@John
From the mini group buy, I confirm that the L.O. for the three different types of extended Ku-Band LNB's is 11.80 GHz and the range is 12.75 - 13.75 Ghz for all of them.
Remind me what's left lol.
@John
Great picture thanks - I'm running the far left one.
Don't worry MB, i'll be here lol.
On this cheap one i have here i'm having to run at 11.794 LO to get the same read out's
Nice to see you both getting some use from the extended Ku-Band LNB's from the mini group buy.
Please wake me up when there are pictures :)
Have faith my Son
s-band
Essex
Who wants pictures? Wiggly lines are much more interesting. Here's one showing the signal level of 13428V over a period of about 1300 seconds (200kHz RBW, 10Hz VBW):
