OCTAGON SF8008 E2 4K UHD
The usb update.bin is in the recovery_emmc.zip from the url i posted
My error, I had only checked the link at the top.
The links are OpenATV 6.3 images, has 6.4 been discontinued ?
ja5on
Vu+
england
6.4 is latest and 6.5 is beta
Most images have the option to flash on line with blue button or software manger and you can add downloaded images also. select image select slot, rr stanby and restart and select recovery mode, then use network multi image upgrade. select image and slot and star upgrade. (no wifi)
If you have a sd card then you can get loads os slots to Extra Multiboot slots for sf8008 and sf8008m [HowTo]
any old image i think will change you firmware also be carefull
List of images
Andrew007
Gregorian Motorised Dish: 62°E-45°W.. various STB's and LOTS of Goodies.!
DoGs RoLeX
@ Channel Hopper and Ja5on, thanks for your replies Guys.
OK here is the story, I am using the SF8008 and want to set-up a new one for my brother.
So at present NO image or Multiboot is on the Box. Its empty. The reason I want the older versions is because
I want to use openATV 6.3 BUT with my favourite Skin. The newer openATV 6.4 versions break the Skin structure
and cause crashes, its obviously NOT compatible with newer versions.
ON the openATV 6.3 July and Aug 2020 versions it WAS compatible and running perfectly. BUT i cant remember which one.
I have, since my own Flashing, had a Microsoft update, which killed my PC and I have lost a lot of Data including these
open ATV Versions.
So I want to check why it is NOT working on later versions.
If you want to have it to see, just ask and I can Post the Skin.
Cheers and regards.Andrew
Andrew007
DoGs RoLeX
As far as your Links are concerned I know them, Thanks Guys, really apprec.
BUT its ONLY the recent 6.3 and 6.4 versions which, I do NOT want anyway.
I am NOT really interesed in more Multiboot Slots either. STABLE and SIMPLE my moto.
And as far as nightly updates are concered if needed I can Add later.
regards.Andrew
ja5on
Vu+
england
regards.Andrew
Hi Andrew
My info was for everyone and multi slots gives you a choice to try other images and keep your own, You get a few multislots anyway without sd card lol
Skin stop working because they dont get updated. So many images and skins plugins etc im sure there is something you like plus they all can be editted to suit you needs.
And for nightly updates you wont get any updates on old 6.3 and if you decide to update to newer image you will have to start over.
What skin is it??
Andrew007
DoGs RoLeX
Thanks for your reply Ja5on, its this Skin
  • Skin-Turbo-MOD-By-RAED.ipk.rar
Andrew007
DoGs RoLeX
Ja50n, I contacted the Skinner and he has told me he Modified the Skin about 7 months ago and it should work for "ALL" OPEN images.
The 6.3 on my own SF8008 has been updated several times in the last few months and see Screenshot nr.10
The other Screenshots are of my Skin. This is working super, no problems .
ja5on
Vu+
england
Well without a crashlog there isnt much anyone can do, unless you report it to RAED and see if he can fix it, Tbh there is so many skins out there
Maybe try Full HD Glass 17 skin,
Or you can mod any screen to your liking too, just a matter of trying
Andrew007
DoGs RoLeX
There is NO Crash Log available because the Skin loads via Dcc.E2 >FTP >TMP and IPK Installer but when I try to
activate it in Usage/GUI afterwards it is there, BUT it will NOT install and the Skins DO NOT change.!
open ATV Versions.
Perhaps I have misunderstood . If you programme the receiver with the multiboot function and use the working openATV 6.3 with yourpreferred skin, you can experiment with other images in any of the three remaining slots (1 have only tried three in total, OenATV 6.4 /Define / SatDreamGR )
ja5on
Vu+
england
Yes that correct but there was new multiboot and recovery system so any image before April 17th, 2020 or a backup image cant be used without adjustment. I think some people try to install newer images on old recovery system and have trouble, i guess it down to when you purchased the box.
Tbh there is some very good images and skins out there and if you dont try them how would you know :p
Andrew007
DoGs RoLeX
My SF8008 is from July 2020, so after the new Multiboot/Recovery system was introduced.
So thats all good.!
You are right thre are many images and Skins out there and some really good ones.
I have also Tested HDFreaks, OpenVix, PUrE2, OpenPLi and as you can see still have
openATV and openPli on my Multiboot, So I do Test.!
I have tried many on my DM MIPS Boxes and have now moved on to ARM 4K Boxes.
I have finally found and made it into what I think is a very stable Image and Skin.
Thats why I would like to keep the Image and Skin. Thats ALL.
If you cannot help with the image I asked for, can you please explain how to best
make a FULL BackUp onto a USB stick and then Flash this into my Brothers new Box.?
I have made several BackUp and they are ALL stored as images, on my HDD it is in fact
only the 256 GB MicroSDCard, BUT it has been mounted as HDD, see attached Pic.
Its a little confusing because they are ALL different in size, If I make several BackUps of
my Images on the Multiboot SHOULD they NOT be ALL the same size?
Would either one of you know what to do or should I look somewhere else?
Thanks Guys.
ja5on
Vu+
england
So thats all good.!
Thanks Guys.
They are different sizes because of the plugins etc you have installed.
From my understanding you can use the back up your current image and you could write that to a slot, but last time i checked it made a recovery image.
Try it yourself press blue and select complete backup and check it, then use that to flash your box but i think it will be old firmware.
You have nothing to lose
http://www.octagon-germany.eu/
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10561 11-08-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Änderungen:
1. WEB USER Browser eingebaut. WEBIF - IPTV Setting - WEB USER.
--> WEBIF aufrufen: IP nummer ihres Gerätes ins Internet Browser eingeben (192.168. . )
--> Gewünschte Seiten können per Web Interface eingegeben werden.
--> Mit Fernbedienung im Menu auf WEB USER app Option Taste - System OK.
--> Maus aktivieren im Browser mit der REC (Aufnahme) Taste.
2. WEBIF - DVB Setting - EPG Source eingebaut. EPG Quellen.
--> EPG Quellen können im WEBIF eingegeben werden. (Type: xml.gz)
--> EPG Quelle für DVB Tuner und sowohl für ALLE Internet APPs.
--> Sendernamen im DVB & IPTV müssen mit Sendernamen im xml.gz EPG Quelle übereinstimmen.
3. Menu - System - Sonstige Einstellungen - EPG Source 1,2,3.
--> EPG Quellen können im Menü auch mit der Fernbedienung eingegeben werden. (Type: xml.gz)
4. EPG Quellen auch für EDEM APP eingebaut.
--> EDEM - Option Taste - System OK: EPG Source 1,2,3. (Type: xml.gz)
--> WEBIF - IPTV Setting - EDEM OK: EPG Source 1,2,3. (Type: xml.gz)
5. Stalker nicht supportede URL`s behoben.
6. WiFi Treiber aktualisiert & optimiert.
Changes:
1. WEB USER Browser added. WEBIF - IPTV Setting - WEB USER.
--> Call up WEBIF: Enter the IP number of your device in the Internet browser (192.168..)
--> Desired pages can be entered via the web interface.
--> With remote control in the menu on WEB USER app option button - System OK.
--> Activate the mouse in the browser with the REC (record) button.
2. WEBIF - DVB Setting - EPG Source built in. EPG sources.
--> EPG sources can be entered in the WEBIF. (Type: xml.gz)
--> EPG source for DVB Tuners and for ALL Internet APPs.
--> Channel names in DVB & IPTV must match channel names in xml.gz EPG source.
3. Menu - System - Misc Settings - EPG Source 1,2,3.
--> EPG sources can also be entered in the menu with the remote control. (Type: xml.gz)
4. EPG sources also built in for EDEM APP
--> EDEM - Option button - System OK: EPG Source 1,2,3. (Type: xml.gz)
5. Fixed some Stalker Portal doesn't work.
6. WiFi driver updated & optimized.
Değişiklikler:
1. WEB KULLANICI Tarayıcı eklendi. WEBIF - IPTV Ayarı - WEB KULLANICI.
--> WEBIF'i kullanımı: Cihazınızın IP numarasını İnternet tarayıcısına girin (192.168..)
--> Web arayüzü üzerinden istenilen sayfalara girilebilir.
--> Kumanda ile: WEB KULLANICI uygulaması üzerinde Option tusu - Sistem OK.
--> KIRMIZI (kayıt) düğmesi ile tarayıcıda fareyi etkinleştirin.
2. WEBIF arayüz - DVB Ayarı - Dahili EPG Kaynağı. EPG kaynakları.
--> EPG kaynakları WEBIF'e girilebilir. (Tür: xml.gz)
--> DVB Tuner'lar ve TÜM İnternet UYGULAMALARI için EPG kaynağı kullanılabilir.
--> DVB ve IPTV'deki kanal adları, xml.gz EPG kaynağındaki kanal adlarıyla eşleşmelidir.
3. Menü - Sistem - Çeşitli Diğer Ayarlar - EPG Kaynağı 1,2,3.
--> EPG kaynakları da uzaktan kumanda ile menüye girilebilir. (Tür: xml.gz)
4. EDEM APP uygulamsı için yerleşik EPG kaynakları eklendi.
--> EDEM - Option tusu - Sistem OK: EPG Source 1,2,3. (Tür: xml.gz)
--> WEBIF - IPTV Setting - EDEM OK: EPG Source 1,2,3. (Tür: xml.gz)
5. Bazı Stalker Portal'ın çalışmaması düzeltildi.
6. WiFi sürücüsü güncellendi ve optimize edildi.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10561 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10561 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10561 OK
SW Offline - USB .mupg:
Recovery Bootmenu MMC (E2) SF8008 & SF8008m:
OCTAGON GERMANY SUPPORT
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10562 29-08-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Änderungen:
1. AAC3 und OPUS Audio Decoder Support eingebaut.
2. Nicht funktionierende Stalker Portale behoben.
3. Xtream .m3u APP Login verbessert.
Changes:
1. added AAC3, OPUS audio decoder.
2. fixed some stalker portal doesn't work.
3. fixed some xtream login fail.
Değişiklikler:
1. AAC3 ve OPUS Audio ses Decoderi destegi eklendi.
2. Bazi calismayan Stalker Portaller düzeltildi.
3. Xtream Login giris hatasi giderildi.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10562 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10562 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10562 OK
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10569 14-11-2021
OCTAGON:
SF8008M Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. Multibitrate HLS Play Funktion eingebaut.
2. Stalker Browser api aktualisiert.
3. Chronium Browser und Kodi Zertikate aktualisiert.
4. Xtream M3u und Stalker verbessert.
5. DVB-S2 Tuner CH. Zap Geschwindigkeit verbessert.
6. Internet CH. Zap Geschwindigkeit verbessert.
7. Picons aktualisiert wie Astra19 Hotbird13 Türksat42.
1. Multibitrate HLS Play function added.
2. Updated Stalker Browser api.
3. Chronium Browser and Kodi certificat. upgrade.
4. Xtream M3u and Stalker improved.
5. DVB-S2 Tuner CH. Zap speed improved.
6. Internet CH. Zap speed improved.
7. Picons upgrade like Astra19 Hotbird13 Türksat42.
1. Multibitrate HLS Play özelligi eklendi.
2. Stalker Browser api güncellendi.
3. Chronium Browser ve Kodi zertifikalari güncellendi.
4. Xtream M3u ve Stalker uygulamalari iyilestirildi.
5. DVB-S2 Tuner Kanal gecis hizi artirildi.
6. Internet IPTV Kanal gecis hizi artirildi.
7. Astra19 Hotbird13 ve Türksat42 Picon`lar güncellendi.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10569.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10569.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10569'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10569 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10569 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10569 OK
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
maxi_power
120cm motorised dishes
PT
OCTAGON:
SF8008M Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
And news for Enigma2 drivers/improvements?
Offtensive
Midlands
I am looking to buy an Octagon SF8008 twin. I have had a look on various websites and there seem to be two versions I think.
Is it just the remote that has been updated or were there any updates with the box too?
And if the box has been updated too, would I be correct in saying that if I buy the receiver with the new remote (the one with TV controls) that I am getting the most recent box?
Many thanks,
Offtensive
Manikm909
Small'ish Dish Man
Kent, UK
Many thanks,
Offtensive
I have two. One has a much nicer remote than the other. One is very clicky and plasticky. The other has rubber buttons and quieter. Who knows why and when it changed. Ask the intended supplier which remote you'd be getting
