14w new Russian transponder
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
There are more russian channels listed - Zvezda, Mir24, etc
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
all working on Octagon SF8008 with OpenATV 6.4 ^_^
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Yes they are all back working again.
Satspot
1.2m Triax dish
Ireland
Another two channels have appeared on 11627 V 2984
11626 V,2984,3/4,8psk-TVRus Europe 4,new
11632 V,7347,34,8psk-Synterra,new
suedschwede
DE
Scan found and lock
deeptho
Europe
Also working in neumoDVB after fixing a bug in the tsduck code which is used to extract the t2mi stream
The code still needs to be uploaded to github
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I am posting my report from 14.0W @ Express-AM8 with the three T2-MI transponders activated
11544 V,14181,3/4,8PSK,PLP 0-RTRS,
11563 V,14585,3/4,8PSK,PLP 0-RTRS,
11646 V,14182,3/4,8PSK,PLP 0-RTRS.
I can scan and watch the channels on 11646V on my Edision mio+ with openatv without adding the code to Astra-sm. how is this possible? I can’t scan the other two transponder though. Maybe this weekend I try editing Astra-sm.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Europesat
strong
Yemen
All t2 mi channels working smoothly with Starsat 200 4k box
mikeisyou
Feed Hunter
England
Satfaca
Melmac (46N, 14.5E)
Melmac
Two new transponders:
11.023 H, SR 4856
11.542 H, SR 8264
SimonE
Gloucestershire, UK
11023H produced a couple of Russian HD channels. Karusel Int 4 and Probeda Int. 11542H 8264 nothing received here in the West of England. Maybe a different beam.
Satfaca
Melmac (46N, 14.5E)
Melmac
Not a different beam I think but the signal is definitely almost 5 dB lower related to 11.023 H.
Adam792
Cheltenham
A nasty thought has just occurred to me on these, regarding them being reported as the Crimea versions.
I wouldn’t be surprised if they’re intended to be used to replace Ukraine’s DTT transmissions (which are also delivered to the transmitters by T2-MI over satellite), in areas captured by the Russian forces.
At least one medium wave transmitter in the east (810kHz) has apparently had its output of the Ukrainian Army FM station swapped for the Russian Vesti FM in the last few days as that’s happened.
And it looks like it’s started -
SimonE
Gloucestershire, UK
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
11023 H 4856 2/3 (Fixed-1)
11540 Н 8266 3/4 (Fixed-2)
