neumoDVB
Tests with 6983 with low symbol rate streams with neumodvb at 5.0W.
Fortunately, they can be locked and scanned manually with this card.
On the other hand, with the blindscan driver, I was able to stream these transponders with the DAB/DAB+ application.
There were no problems with the 11 Rai radio stream at 11013 V.
Too bad that the spectrum is not as powerful as the possibilities this card has. Having said that, don't let it be understood that I don't appreciate what Deeptho has done. Now that I'm working with his app, I realize how many more problems he has to solve with his app if he wants to be at the level of the dxers working under Windows. What I am saying now is only valid if he has set out to do so :Y
I scanned the BBC mux at 27.5W. Somewhere you mentioned this package, but I didn't remember how to edit the package to manually insert the Video/Audio PID.
Of course, I would ask too much to show me where (if) there is the possibility to work emu? As you can see, I'm not asking for a key!
deeptho
Europe
I tried it a long time ago and it worked. I don't remember the details, and there were some oscam related issues to
work around, like confusion between keys (easiest to avoid with a minimal oscam configuration). The first step is indeed to manually enter the correct video_pid in the services list, as explained in the documentation. All the rest is basically oscam-related (both regarding possibilities and problems).
In general, decryption seems to work fine with official viewing cards if they are supported by oscam. I have tested a few.
There are so many things to test with Deeptho's app, Neomodvb, all the more so since it's new for those who work with DVB cards on Linux. The first test I did on my toroidal, Wavefield, with 16 LNBs, for 16 satellites, now only 15, because the last one on the bar is no longer getting signal at 7.3W, being now on the MENA beam, impossible to pick up with a 1m antenna in my area.
I checked the application with the tbs6903x card, because, as Deeptho says, it provided support for demod stid135, but more importantly, for satellite reception enthusiasts to have the right tool on Linux, like have those who work on Windows.
I have to admit that I had a little difficulty getting to grips with the application to use it with the 6903x for I set the app to DiSEqC 1.1, as it is recommended for more than 4 LNB.
I checked the application with the tbs6903x card. As Deeptho says, it provided support for chip stid135, but more importantly, satellite reception enthusiasts have the right tool on Linux, like those who work on Windows.
I have to admit that I had a little difficulty getting to grips with the application to use it with the 6903x, for I set the app to DiSEqC 1.1, as it is recommended for more than 4 LNB.
This setup didn't pose any problems. Everything is evident in the instructions as ABC. I started with port 0, at 42.0E, the first lnb on the antenna(Crazyscan under Windows begins with 1 for DiSEqC 1.1), and the last is port 14, which is at 4.0W, lnb on Amos 4/7,(you can see this on the pictures below).
The difficulty I mentioned before was due to the 6903x's slow response to my commands and the way I approached this operation. Being only a test, I chose to scan only one transponder on each of the satellites on the toroidal. I succeeded on the first attempt to check the first two satellites, Turksat and HellasSat, without any problem, but when I had to scan with the circular lnb at 36.0E, the application didn't respond as on the first two satellites.
Of course, I set in the application the circular polarity, Right/Left, but the Neumodvb still delayed to I thought of restarting the application, taking care to enter the lnb settings for 6903x, the 11th in the table with cards in the application. Even with the circular polarity set for Express-AMU1, I didn't get a signal.
Finally, I set the lnb to Linear, and with a bit of patience, the card finally responded and scanned this satellite. I continued with the 4th lnb, at 33.1E, but again the signal finding and locking were long-awaited.
I had the same problems finding and locking the signal at other positions. To cut a long story short. I managed to scan all 15 satellites on my toroidal.
At some positions, the application was failing, and I was getting it from starting from the beginning, i.e., choosing the lnb assigned to the 11 cards I was working with. It was only later that I realized that I got more efficiency in scanning if I didn't exit the application after scanning a
But this approach is not always guaranteed, even more so when the signal is unavailable, even on the same satellite. Plus, as those who work with this card know, the 6903x has a higher latency when responding to a weaker signal (but it sometimes happens on a strong one).
Even though it took me a long time (the first test of this kind) to scan 15 satellites, I'm finally impressed that I could work with Numodvb on several satellites.
For the errors that occurred during the tests, either my fault or the application's, I will attach the log from /tmp/. Deeptho will see what kind of errors and what causes them.
I thought of posting the pictures of the toroidal satellites I scanned. But I limit myself now to attach only the first one, at 42.0E, and the last one, at 4.0W. If Deeptho wants to see all the satellites scanned with DiSEqC 1.1, I will make it available if he asks.
I gathered from Deeptho's comment that the algorithm used for the 6903x card is different than CrazyCat's.
I don't know if this affects how the visual signal appears on the spectrum because there is a slight difference in the range, say, at 13.0E, between what Neumodvb and Crazyscan show us. With the former, the signal appears weaker and does not find any useful signal, while with the latter on Windows, it stands out and can be scanned and locked. In general, the signal on the horizontal polarity appears weaker on the spectrum than the vertical one. From this point of view Crazyscan, under Windows, is more efficient.
But I will come back to this on another occasion. Sorry for loading the topic with long text and many pictures until then.
Once again my thanks for what you do for the satellite enthusiast community :Y
ps_(I don't know if it matters a lot, but I add that I used Diseqc 1x17 EMP Centauri in these tests. Most of the lnbs on my toroid are from 2007/2008, most are Strong. I installed it in 2008)
  • neumo.zip
deeptho
Europe
Satesco,
I am happy to hear you had some success, but there is something wrong with the way you compiled the
code and it may be an old version. This is a pity as bugs are fixed from time to time. I also prefer
not to spend time looking for bugs which have already been fixed. So the message is: if you encounter
problems, always check if they happen in a recent version as well.
It is all work in progress, Sometimes the latest version will have new bugs of course.
The code stores the version number in the log file, but in your case it just shows
BUILD=N/A TAG=N/A BRANCH=N/A
Probably git was not installed on your computer? It makes it impossible to know the version.
What do you mean exactly by "slow"? The scan can take up to 30 seconds or more, but that is just how dvb works. Some information
is only transmitted every 30 seconds. And of course, for low symbol rates locking can take some time (card related).
Also, earlier I fixed some bugs which could cause slowness, Not sure if they are fixed in your version.
You must also understand that after "tuning" a mux, the mux remains active. This is different from tuning in the spectrum dialog.
So unless you stop a tuned mux, you will not be able to tune to another mux on another sat as it will continue to monitor the incoming
stream for changes.
In general there is no need to restart the application, but of course when there is a problem, it is much easier to figure out what goes wrong
after a fresh start. it rules out a number of problems.
This is one of the bugs that was fixed at some point. Also, be careful, because right and left can be swapped on some lnbs (e.g., inserting the polarsing plate in a 90 degree different orientation). There is an option to correct for this in neumodvb.
Why not run the scan from the spectrum plot window? It will provide you a lot more info on what is going wrong. For instance, it is easy to make
a mistake with diseqc. I use the same switch as you. I rarely have problems, except entering the wring diseqc config, and of course some
bugs (fixed).
Very recently I also noticed a problem with tvheadend: with "diseqc" repeat enabled it can cause something (the lnb or more likely the card) to
get into a completely buggy mode where some parts of the spectrum are heavily distorted and cannot be tuned. The problem is rare,
but when it occurs, the symptom is that only DVBS QPSK muxes can be tuned. Difficult to understand, but it shows that strange things can
happen. For me it happened when installing an extra LNB, which made it extra worse, because I first thought the problem was with a switch
or an lnb. The fix is easy: power off everything or reload the drivers.
This is always a good idea, but what is a bit complicated is understanding where your problems are. It would help if
you could mention specific mux on a specific sat, along with some information on how weak it is, and more info in what exactly goes wrong,
and what you did. For example,. there are many ways of scanning and tuning.
By default, the baseline of the spectrum is set to zero, because nobody wants to see the decay from low to high frequencies caused by a long cable. That means what you see is the SNR on top of an arbitrary baseline. If you want to see the incoming RF, that is also possible
and is explained in the documentation, but it is not the default.
The H spectrum in your graph is indeed "weaker" in the sense of thise muxes having a lower SNR for some reason. The RF level may
be higher or lower because of the baseline subtraction.
There is also something else: the way RF power is computed in the original drivers was rather buggy and those bugs may still be
in crazycat's drivers. A second problem was perhaps fixed, but in earlier versions of crazycat's spectrum code, the spectrum was obviously wrong, sometimes jumping down by many dB due to yet another bug. And last but not least: there are multiple versions of the 6903x cards, some with an LNA and some without. There is also no way of knowing which is the correct RF level, without comparing to a spectrum analyzer output, but
as we all know, RF level does not matter much, and it is very difficult to even read it properly with most cards. The 6909x and 6903x cards are
exceptions and the result should actually be more reliable than with other cards, especially for the cards without a low-noise amplifier, of course after fixing the driver bugs. I am less sure about the versions with an LNA, because some documentation is currently lacking for those.
It is always useful to know the setup as it makes it easier to trace problems.
I currently have: 5W, 0.8W, 1.9E, 4.8E, 7.0E, 9.0E, 13.0E, 16.0E, 19.2E, 23.5E, 26.0E, 28.2E, 330.E, 39.0E and 42.0E
on my T90. A beautiful and well-designed dish if you ask me.:Y
All LNBs are quads and are connected to 4 receiver inputs, 3 via the same emp centauri as yours. The other one is connected
to a 10x1 switch and 2 4x1 switches, Some of the switches also take two more inputs from a laminas dish on a rotor.
To make the LNBs fit (some are close) I used some 3d printed lnb holders. It is easy to achieve 2 degree separation with those.
Deeptho.
I realize that bugs occur with every release. That's why I don't insist on them, even more so with 6903x. Those who work with it know that it is a card that poses problems for driver developers, both on Windows and now on Linux.
Firstly, I'm interested in whether your application can be at the same level of functionality as under Windows and whether it can outperform dvb applications under Windows.
But I'll talk about that later after I do some more tests with neumodvb.
And for that, I will consider the observations you have made now.
As for what version of drivers we use, or version of neumodvb (now v.0.8.8), it would be good to specify on your site expressis verbis this. On Github are mentioned only kernel versions and patches are.
And in the case of Neumodvb, as you rightly said, it is a work in progress, which implies that such a user has a better familiarity with your application. I try to use it more often as I leave other activities aside.
You once said that you don't have stv091x-based cards, but I wish you could provide better support for 6983/6903 cards as neumodvb has for 6903x/6909x cards! I can imagine that it's not easy to work remotely on hardware support that is not on your pc, but if you think you would be willing to do it anyway, I suggest you work on my computer.
I have tested some low and high symbol rates with 6903x and 6983 at some positions with your application. With 6983, I have locked the lowest symbol rate of 185, on 11697 V(Radio Mars) at 30.0W. The 6903x card does not even detect the signal. What do you say?
Instead, with this one can lock the highest symbol rate is used on satellites, of 107140 Ks on 11013 H and 11137 H (Data services) at 15.0W.
Can we hope that neumodvb will lock the low symbol rate as IQmonitor?
deeptho
Europe
Deeptho.
Of course it can be at least as good or even better. That doesn't mean it is.
It is not the version of the drivers that I asked for, but of the user space program.
No pressure of course. It is a hobby, not work.
I do have an stv091x-based card. What I said was that I do not have your specific brand and that it does matter, because it might use a different tuner and tuner driver. That means: experimenting with the driver, which can be tricky when done remotely (risk of crashing the computer)
I could have a look, but then you need to provide me with ssh access if possible. I prefer that over teamviewer. It does require activating some
port forward on your local router. Not sure how familiar you are with that. Of course, the details do not belong on this forum.
What I say is: for the tbs6903x, the official minimum supported symol rate is 1Mbp/s but I have been able to lock down to 256 kb/s. It requires
a good approximation of the frequency and symbol rate, which is why a spectrum is helpfuk.
There are some things that could be perhaps adjusted in the drivers to lock some narrowband signals, but that requires a signal for experimenting and typically a lot of time. The spectrum I get is below and has a number of peaks. They are not detected as candidate peaks, but that is probably a matter of some choices I made. They cannot be locked either. If they can be locked under windows, then it must be possible in linux as well
And the spectrum on tbs 5927:
And indeed, this card locks the signal with my blindscan drivers and reports
a working radio channel named "Qbit Program 1000".
The full spectrum looks like this: not too bad, but much less detailed than tbs6909x:
Can iqmonitor lock this 185kbit/s mux on tbs6903x?
I tested again at 10.0E with card 6983 on transponders with a low symbol rate, Radio Maria. As I said before, neumodvb sees and locks the signal on almost all these transponders. But what puzzles me most is that it does not find the radio services in question. Moreover, the application generates other transponders with the same parameters, which I never saw on Windows with Crazyscan. I could say that they are fake if I didn't consider what Deeptho noted; that is, it applies a different search logarithm than what is implemented in Crazyscan.
It doesn't bother me that these transponders are found at a few MHz differences from the real one, but that the application doesn't identify NIT and SiD from the stream even though the signal is strong. With Crazyscan you can stream and listen to Radio Maria with any DVB player.
Added:
As I was getting ready to post, you replied to my previous message.IQmonitor does not lock 185 with 6903x. In fact, the application works harder with cards with s2x extension. Ukrainian focused more on stv091x-based cards, and less on other models.
I've finally got the latest version of neumodvb working after problems with the PC (ages spent trying to find why it wouldn't start up again after a restart). Checked PS, CPU, Memory to no avail. The problem was the power switch sometimes making contact, sometimes not, leading me to think perhaps the PS was shutting down occasionally. Solution, a simple press switch replacement :-doh
Needed to install a new distro version (Ubuntu 20.04 mentioned in the readup) - the version I had caused the build problems I mentioned earlier
here.
Kernel still my go-to version, 5.9.0-rc7-tbs+
Hi Llew,
If you think it helps, especially since you will be working on Ubuntu 20.04, I can provide you with the driver version compiled by Deeptho, 5.13.0.39-generic. I'm working on it now and testing with neumodvb.
deeptho
Europe
Added:
I am afraid this is a matter of not understanding how neumodvb works: the numbers you enter define where to search from. The frequency found is a different one. The very large difference could be due to using an old version of the program. Please install the latest one or at least report the installed version
I seem to have a "bug" in my head :D, but what does "the user space program" actually mean to you?
deeptho
Europe
The program you start, so neumoDVB and not the drivers.
The version I use is 0.8.0, I think it's the last one you published. Or is there another one I don't know about?
deeptho
Europe
This is what I was after. In the mean time the version is 0.8.2. Some bugs fixed since 0.8.0 relate to faster scanning,
scanning not ending and some crashes.
Thanks for the info. If I wouldn't ask too much, it would be nice to post updates (mentioned version) to neumoDVB on your Github page.
Latest version looks good -when I get a chance to use it. On my PC it keeps shutting down after a few seconds.
Errors -
This attempt at a spectrum scan OK, but seconds after wards, it retreated into oblivion.
Blindscan likewise. A third of the way through, it disappeared.
Tuning a TP stays up a whole thirty seconds...
deeptho
Europe
deeptho
Europe
