Turksat 4A Ka Band A now active
rs100
CM 1.0 DISH
Now on Gibby 1.2.
A decent increase of signal, even on 18738L, though not enough to lock (as we have noted, signal reception differs considerably over 24 hours on these TPs. For my location, best noon onwards. )
The Saorsat's output gain suffered when it was modded, so it has a 20dB inline amp to RX.
Its 'twistable' cap has a slit for a dielectric insert for linear TPs.
Is it easy to mod a ka triax lnb ?
You need good eyesight and a low band (9.750GHz) DRO puck from a dead or unused Ku LNB. And something to stick the puck on to where you've removed the original one from the Saorsat LNBF.
I used a tiny piece of double sided adhesive tape. I considered superglue, but I've had no problems using tape (so far it's been sufficient enough.).
Oh, and a diamond drill bit to remove a little of the ceramic from the puck.
SimonE
Gloucestershire, UK
All Ka-Band signals from this satellite seem to have been turned off.
Yep , looks like Simon - nothing seen here also.
SimonE
Gloucestershire, UK
Signals have returned @ 42E 18710L, 18739L and 18774L.
dreamsat
germany
thanks @ SimonE
manny new programms:Y:Y
With my modded Saorsat LNB. (StreamReader's upper spectral range changed to allow a different LOF in selecting Inverto Ka in Crazyscan)
Not locking 18738L though :(
s-band
Essex
Hmm, not so good here but I have 0.9dB ground noise
AN8024 on 1.2m
dreamsat
germany
reception is stable here
s-band
Essex
Iv'e checked it again today and is lower on levels than the day previous
Thanks, I've swapped LNB/feed so can't check but the view of 42E clips the roof and trees which doesn't help.
dreamsat
germany
my scans
a little bit raining weater
fereshte
Bulgaria
2,30m prime focus dish with 3 LNBs - C ( Linear plus Circular ) and KU ( Linear ) ; 2,05m prime focus dish - KU circular and in future hopefully - ka band - 103E - 50W ; Octagon SF4008 UHD ; Edision Primo IP ; Inverto Flange white series ; Invacom quad; 36" motors; Especta and Moteck satellite positioners.
Bulgaria
Hi again, i ve bought from aliexpresw Band A ka band lnb. In Bulgaria what dish size i need for 39E - 42E ka band reception? I have 100cm antenna for 16E and 7E and it works good. In comparison to them how much strong is the 39E 42E ka band signal? Thanks sincerely!
dreamsat
germany
my values are 2.20 m. I think it should be 1.50m to 1.80m. The transponder 18709 could also work with 1.20m. Bulgaria is also in the maximum zone.
fereshte
Bulgaria
Bulgaria
So there is no chance for 80cm? For 39E also? And also on enigma2 what should be the oscilator frequency do set up?
dreamsat
germany
No, no chance for 80 cm. You can still try it. Sometimes the footprints are not correct and it works. The oscillator frequency should be on the LNB.
best regards
fereshte
Bulgaria
Bulgaria
I will try it on multifeed on 220cm, there must be something locked on signal. Sincere thanks for the vast response!
fereshte
Bulgaria
Bulgaria
I tried with this one on multifeed nothing. First i bought the wrong one 18,2 Oscilator, then a friend moded it to 17,2ghz but nothing on 220cm. Perhaps the remode setup is not made correct. First of all is this a LNB for offset or prime focus dish? If it is suitable for offset and the signal is weak it is normal all to be zero quality signal or the second reason wrong modding the original 18,2ghz LNB to 17,2 ghz oscilator freq. I checked both 39E 42E the L R plate is in the LNB, i rotated it but still absolutely nothing on 17,2ghz. What ideas you have? I suppose i have to buy 17,2ghz original after a single test on offset dish.
dreamsat
germany
i can't see
please make a separat tread for LNB and modding. this is the 42° easr tread!!
best regards
dreamsat
germany
many programms changed at 42 east
