Help Needed to get my Octagon SF8008 Set up to move to different satellites when selected
danaddison
100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
Help Needed to get my Octagon SF8008 Set up to move to different satellites when selected please thanks, please see my screenshots below, i have my dish/motor alighted to 0.8w and have strong signal and quality, now i need help inorder to know what to do to get my dish to move to different satellites if you know how to do this on this device (Octagon SF8008) please let me know asap thanks
Is this part correct? i have selected all the satellites i want to scan?
I Need step by step instructions of what to do next please
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
To start you need to check what sort of
Line of sight you have
In uk usually 100cm dish can receive signal from
60 east To 60 west approximately
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
To check line of sight you can use dishpointer website or post some pictures of your dish
danaddison
i have great line of sight, im using a 100cm sat dish and motor which is attached to pole in the ground, i have it aligned correctly, its at position 0.8w atm and want to get my octagon sf8008 to move it to different satellites when selecting them can help with that please? like what part do i select to get the dish to move to a different satellite on the octagon ? please post screenshotss/videos showing your settings thanks
heres a pic of my dish (taken from my cctv camera) (near but not infront of my dish) so i can keep an eye on it, need help with settings on octagon sf8008 only please
First of all, have you verified the dish does move away from 0.8W and back again when you reset the motor to true south ?
King's Lynn is more or less 0.4 East, not 0.8.
danaddison
i can move it to other positions using dvbdream as of yet im still trying to work out how to get my octagon sf8008 to move to different satellites its at 0.8w at the moment, what do u mean kings lynn is more or less than 0.4 east not 0.8? should i change it to 0.4 east then? can u help to get my sf8009 set up inorder to move to different satellites please??
EnoSat
enosat.euweb.cz
Slovakia
Is your dish in the sea?
danaddison
No it isnt in the sea lol, kings lynn, all i need to know is what settings to change to get the dish to move to different satellites on the sf8008 thats it the dish is aligned correctly thats all u need to know please help with what settings i need to change thanks!
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
If it's set up correct just enter your longitude and latitude settings in usals.
danaddison
I have done that, then what do i do to get it to move to different satellites? Using what option do i use to select a different satellite? Do i change it from advanced to simple? and do i input the sat frequency in the positioner setup menu under goto?
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, if everything is set up correctly on motor & receiver, i use advanced and configure one satellite to use either diseqc 1.2 or usuals, the rest of satellites i want will use the first setting saved. Reboot the receiver and select from channel list the satellite you want to move to. Diseqc 1.2 you need to save each position manually, usuals not needed.
danaddison
ok thanks ill try that aswell its so hard to get the settings correct
stel883_
Vátika, Greece
I'm at work atm, so can't give some screens, for usuals in tuner page set lnb to lnb1 for all satellites you choose, for diseqc 1.2 in postioner page save each position manually, if i remember correctly.
danaddison
ok will do thanks does my screenshots look correct to u?
i need step by step instructions to set up my sf8008 up correctly inorder to move to select satellites 13e, 23.5e, 28.2e, 10e, 16e,
please see my screenshots below for my latest updates and let me know if they are correct or not
EnoSat
enosat.euweb.cz
Slovakia
Set correct your location
next go Signal Finder
if Positioner(motor) set correct after select new Sat and transponder show LOCK signal
PS: use actual satellites.xml in box
danaddison
thanks ill try that now, and thanks for the screenshots, my screenshots have a different long and lat on it because i dont want people knowing my exact location, but when im not posting on here i correct them to my long and lat :) btw my default satelliteim positioned to is 0.8w
this is what im getting now
stel883_
Vátika, Greece
Is your lnb on dish single? And configure one satellite for a start and move there by channel list or signal finder.
danaddison
yes its single, ok still not getting signal on signal finder but i am able to watch normal tv how does that work? its not liking me for some reason still need help please from the beginning step by step
EnoSat
enosat.euweb.cz
Slovakia
GoTo 0 moving on 0.3E (cca Thor7) ?
motor-pointer-jpg.131782
Laltitude angle is set to 53 degrees ?
dreambox1959
46.3N-4.3E-FRANCE
france
if you have a diseqc motor you have to set it .
it it a usuals model ?
if you have still done it , so select advanced in tuner menu and affect a sat number in this menu
