Telstar 12 Vantage.
Blimey not much left of interest on 15W these days! Just had a quick look after rigging an lnb for 14W.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Indian Wells Open replay - Alcaraz-Norrie now
Previously - Nadal-Kyrgios
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
New - MTN Worldwide TV is on [15.0W] 11377 Vertical 8750 3/5
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Good spot. Not sure if it's just my box though most of the channels don't seem to carry the PowerVu encyption flag, though obviously they are encrypted.
dreamsat
germany
two data (video stream) transponders with a high symbol rate is S2X mode
I have 11014V on 15W dreamsat. Or it it on 14W? Hard to tell where I am.
dreamsat
germany
I only tried it with the 1.20m antenna. if i take the big antenna to check it is really from 15 west sorry.
can you please move the post
Here are the muxes you find at 15.0W, including the two with symbol rates of 107140.
rodscha
and which transponder carries something....worth watching?
Is this MTN channel great?
Not much TV at 15.0W, only a few feeds on the upper band. Unfortunately, the MTN package is encrypted.
I don't see those muxes satesco. I get 10979V and 11036V, and an adjacent one not locked at ~ 11136V.
I checked the two muxes (11013 V and 11137 V) at 15.0W; as you can see in the screenshot, both have the same symbol rate-107140. Look at the time and date on my Crazyscan.
I think the errors you have on the spectrum may be due to the card you are using, probably 6903. I think that's why the errors on your spectrum are occurring.
But..., it's not excluded that they're coming from another beam(T12V North Sea 56), which doesn't cover my area.
Because these transponders have this high symbol rate, they can only be locked with the 6903x/6909x card, which has the stid135 demod.
(Strangely, FlySat deleted my report on these two transponders, because other users failed to catch and lock them. It happens this often, such as false reception reports)
Checked with TBS 6903X.
I can now detect the parameters of 11138V. The transponders 10979V and 11036V are almost certain to be on a beam such as North Sea 56 as you suggest.
So perhaps your TP's are on one of the MED beams, as if they are on the Europe and Middle East beam, 11013V would clash with the North Sea beam I am supposedly receiving?
EnoSat
enosat.euweb.cz
Slovakia
10.95-11.2 GHz Ku-low band (EUME)
112.5 MHz bandwidth transponders
TP-1 11014V North Sea beam (S1)
TP-3 11014V Med Central beam (S3)
TP-5 11014V MidEast North beam (S5)
TP-2 11138V Med West beam (S2)
TP-4 11138V Med East beam (S4)
TP-6 11138V MidEast South beam (S6)
TP-23 11264H NorthSea beam (S1)
54 MHz bandwidth transponders
TP-61 10983V Europe beam
TP-62 11054V Europe beam
TP-63 11107V Europe beam
TP-64 11169V Europe beam
popovp
Varna, Bulgaria
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
11377V is the new frequency for the MSNBC Power Vu mux - it moved frequencies a couple of weeks ago.
The "BBC1" apparently has a bit rate of 80b/s - thats not going to give much of an image :-rofl2 At most a static card. I cant get any signal coming off that frequency currently though
FC GD
Stockholm
11375 V,8748,3/4,S2-MTN TV package(enco),
12597 V,45000,5/6,8PSK-Service +Navy TV
Thank you both for the information :)
