36E (Eutelsat 36B)
Satfaca
Melmac (46N, 14.5E)
Melmac
Recently the modulation of the Tricolor package has been changed from 8PSK to QPSK-S2, consequently gain needed for lock split almost in half.
Despite linear feedhorn/LNB I still get enough to lock this single frequency (12.149 LH).
Indeed, I also checked with IBU linear lnb with 1.10m antenna.
The strongest signal is right on 12149 V, over 15dB with lnb linear.
Here is how the signal looks on the other muxes with linear lnb(1.10m dish) and circular lnb(T90).
Such a mode helps to lock the signal.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Some frequencies of Circular Polarization of the Tricolor with a classic Lnb can be reached again.
Ramino.Italiano
Eutelsat 36
Italy
I am from Italy and was in South Africa and I bought the DStv decoder with 3 months subscription but Sadly I couldn't lock the DStv signals in Rome. Even with 1.20 cm
EnoSat
enosat.euweb.cz
Slovakia
you must use a dish of at least 180-220 cm
EnoSat
enosat.euweb.cz
Slovakia
12245H or all ?
EnoSat
enosat.euweb.cz
Slovakia
:Y
it is true that Rome has a much better position for receiving DSTV than us further north :unsure
Move the mouse over the name 4Himdj and press Start conversation
New Members are unable to start conversations. 4Himdj should send the first message, Ramino.Italiano will then be able to reply.
4Himdj
1.2 Laminas Dish
Rome
Can you write me back please, as I can't write you any message. If you are in Rome can wee meet if if you can help me in receiving this satellite
Ciao ti ho scritto in privato
Lexzie
TBS 5925 USB-tuner
The Netherlands
Anyone else succes in receiving these circular signals further west?
What's the easiest frequency to lock?
I see Express AMU1 is at 36.1°E and Eutelsat 36B at 35.9°C.
Since I have received nothing from AMU1 yet I have to focus my 1.8m dish at Eutelsat 36B, but I guess I have to turn it a little bit to the east to receive AMU1.
I use a circular LNB.
Lexzie
TBS 5925 USB-tuner
The Netherlands
No-one in West Europe receiving this?
@nelson_b received a few Russian transponders in the past on his 1.8m and 2.4m - in North West UK.
Can you see any signal from the Russian beam at your location? I suspect some South African transponders, which share frequencies, might be more of an issue there.
