Arabsat BADR-8
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
just to confirm,Oman weaker than others (Mauritania;kuwait)
still no trace of 12073...
No reason : "no trace of 12073"..
you have to install your dish "dans les règles de l'art" and use a required dish, minimum dimension.
Williams1 is receiving, with a 100 cm, this tp 12073H with a level of 10.1 dB in UK..
I'm living in the east of Belgium and the level is a 8.9 dB with a 90 cm dish during bad winter conditions (5cm of snow).
AhmadIraqi
StarSat , 90cm, Inverto
Iraq
Regarding this Feed, what is its content? Because I didn't receive it before? Is it really on Badr-8?
11​
AlexSosa
27.11.2023​
12736 Н
DVB-S2/8PSK​
7400 5/6​
feednew SRBadr-8 FSS EMENA 43-48 dBW
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
11919 H DVB-S2/8PSK 27500 3/4 here in my place, EMENA beam only
An Egyptian Feed, perhaps by name.
I have No Signal here.
Is it possible that this feed is on the neighboring satellite, Astra 3B @ 23.5° E?
23​
Stanley_Cassidy
21.01.2023​
12738 Н
DVB-S2/8PSK​
7200 3/4​
feedAstra-3B Europe Ku
-Indeed, it is an Egyptian feed. He can't be at 23.5E. No Middle East feeds are transmitted in the upper band at this position.
-It depends on what device you are looking for the signal and its strength. But it is not always possible to find or lock a signal, even a strong one, with dvb cards.
It also depends on the utility/apps used. For example, I locked 12736 H with the tbs6983 card with the IQmonitor app. As you can see from the pic, LM is at -0 dB, so below the threshold, although the signal is strong, 12.3 dB.
@william-1
Do you have a list of frequencies/channels that you were not able to get before that you can now receive re 26.0E?
I am thinking if you are getting new stuff now that used to be on Badr-5 and Badr-6 then it is a good candidate to have migrated to Badr-8?
Badr-7 is probably not a factor for this type of comparison as it was almost impossible to get a frequency to lock from at a UK location.
Here are a few that were not there before Badr-8 arrived.
11919 H 27500
12149 H 27500
12245 V 27500
12456 H 27500
12730 H 3300
12706 H 2200
Few more just scanned in,
12733 H 2400
12669 H 7200
12736 H 7400
That is it for now....
AhmadIraqi
Iraq
Also, I receive this Freq, 11685 V 7980 , weak signal here
satelliclub
Eutelsat 5 West B + Eutelsat 9B
Tunisia
12149 H still on Badr 4
I not have a signal in Tunis,Tunisia to 11685 V 7980 , this freqency is in Central Asia Beam
