neumoDVB
RyLe
France
Wavefrontier T90, 8W to 28.2E
TBS 6909-X, TBS 6904SE, TBS 6983
France
That's what I first thought and I restarted the procedure from scratch but I got the same errors.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Same in updateDVB scans OK so not a signal issue.
I also thought it was a signal problem when I first tried to scan terrestrially, to no avail, after neumoDVB's update two months ago. Still, I didn't know that the app was updated three weeks ago, probably expressly to fix the terrestrial scan.
After updating neumoDVB today, I managed to find the terrestrial services. :Y
So it wasn't a signal problem.
deeptho
Europe
I have updated the drivers to support kernel 6.8., No new functionality...
RyLe
France
France
Hi and a big thank you for this driver update :)
What are you using to scan with satesco?
Update didn't fix my DVB-T problem.
I've been trying with the TBS 6522 with no luck. Only works with the Sony USB stick.
I have a TBS 6220 in my other PC, but that only has Windows.
You're right, @Llew; I should have mentioned the 6504 card I used for terrestrial scanning with neumoDVB. :)
OK, thanks. Must be TBS T/T2 card specific.
If I get a chance, I'll try the TBS 6220 in the PC, or better still put a Linux OS in the other one.
The 6504 card is multi-standard(S2/C/T), which @deeptho has supported along with other cards for neumoDVB.
RyLe
France
France
Hi
I just upgraded to Fedora 40 (currently with 6.8.7-300.fc40.x86_64 Kernel).
When I tried to build the blindscan kernel drivers, I had an error:
/home/ryle/blindscan_kernel/media_build/v4l/tbs5931.c:217:90: error: passing argument 3 of '__a' makes integer from pointer without a cast [-Wint-conversion] 217 | adap->fe_adap->fe = dvb_attach(tas2101_attach,&gx1132_cfg, &d->i2c_adap, adapter_nr); | ^~~~~~~~~~ | | | short int *
I bypassed it by adding EXTRA_CFLAGS += -Wno-int-conversion to
/home/ryle/blindscan_kernel/media_build/v4l/Makefile
Probably not pretty but it works for now.
deeptho
Europe
Hi
Probably the correct fix is to replace adapter_nr by rf_in (which is zero). I would not change the compilation flags as that will be one more source of errors in future
