el bandido
- Feb 25, 2009
- Age
- 61
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
- Atlanta, Ga. USA
The SF8008 Supreme looks like it has a great blindscan until it is closely examined. The SF8008 Supreme is logging transponders in a blindscsan that it cannot solve.
61 West-Cband is a good example.
Code:Scan Report < File created on Sunday, March 03, 2024 at 15:57:38 > < Satellite = 61.0W C-band Amazonas 2/3/5 61.1 W > < Receiver = SF8008-Supreme > < Enigma2 Image = Tnap 5.1 > < Kernel Version = 4.4.35 > < DVB Driver Date = 2024-01-04 > < Blindscan Frequency Range = 3625 to 4800 MHz > < Blindscan Symbol Rate Range = 1 to 60 Msps > < Blindscan Only Free Channels or Services? = False > < Tuner = Tuner A: AVL62X1 (DVB-S2) > < 'DVB-S2 QPSK 3730V / 2435 / AUTO' > Tp# 1 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 78.90 > < 'DVB-S2 QPSK 3738H / 2885 / AUTO' > Tp# 2 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 75.23 > < 'DVB-S2 QPSK 3782H / 2434 / AUTO' > Tp# 3 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 72.48 > < 'DVB-S2 QPSK 3835V / 2527 / AUTO' > Tp# 4 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 81.66 > < 'DVB-S2 8PSK 3889H / 7500 / 3/4' > Tp# 5 < [1] C CARIOCA 1:0:19:1:0:1:BAD0F31:0:0:0: SNR = 9.32 /> < [2] 3889H SID 0x01 1:0:1:1:0:1:BAD0F31:0:0:0: SNR = 9.32 /> < Transponder SNR =['9.32db'-Locked], LNB Power = 85.33 > < 'DVB-S2 8PSK 3898H / 7501 / 3/4' > Tp# 6 < [3] SERVICE 03_03_24 (Radio #1) 1:0:2:2:0:0:BAD0F3A:0:0:0: SNR = 9.29 /> < Transponder SNR =['9.29db'-Locked], LNB Power = 87.16 > < 'DVB-S2 8PSK 3907H / 7500 / 2/3' > Tp# 7 < [4] BOA x BAN 1:0:19:1:0:0:BAD0F43:0:0:0: SNR = 7.62 /> < Transponder SNR =['7.62db'-Locked], LNB Power = 87.16 > < 'DVB-S2 8PSK 3941V / 5000 / 3/4' > Tp# 8 < [5] SBTRS_HD 1:0:1:CA40:652:652:BAD8F65:0:0:0: SNR = 12.04 /> < [6] SBTRS_1SEG 1:0:C0:CA58:652:652:BAD8F65:0:0:0: SNR = 12.04 /> < Transponder SNR =['12.04db'-Locked], LNB Power = 84.41 > < 'DVB-S2 16APSK 3946H / 7500 / 2/3' > Tp# 9 < [7] 3946H SID 0x01 1:0:1:1:A0:0:BAD0F6A:0:0:0: SNR = 9.97 /> < Transponder SNR =['9.97db'-Locked], LNB Power = 89.00 > < 'DVB-S2 8PSK 3959H / 3750 / 2/3' > Tp# 10 < [8] ALTV 1:0:0:1:0:0:BAD0F77:0:0:0: SNR = 8.73 /> < Transponder SNR =['8.73db'-Locked], LNB Power = 86.24 > < 'DVB-S2 8PSK 3968H / 9875 / 2/3' > Tp# 11 < [9] TELEFUTURO HD 1:0:1:1:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < [10] LA TELE HD 1:0:1:2:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < [11] NOTICIAS PARAGUAY 1:0:1:3:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < [12] MONUMENTAL TV 1:0:1:4:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < [13] PRO TV 1:0:1:5:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < [14] E40 TV SD 1:0:1:6:1:2AF:BAD0F80:0:0:0: SNR = 8.17 /> < Transponder SNR =['8.17db'-Locked], LNB Power = 89.91 > < 'DVB-S2 16APSK 3971V / 6741 / 3/4' > Tp# 12 < Transponder SNR =['9.29db'-UnLocked], LNB Power = 85.33 > < 'DVB-S2 8PSK 3975H / 2500 / 2/3' > Tp# 13 < [15] ALESP MPEG2 1:0:1:1:1:1:BAD0F87:0:0:0: SNR = 7.6 /> < Transponder SNR =['7.6db'-Locked], LNB Power = 82.57 > < 'DVB-S2 8PSK 3983H / 7501 / 2/3' > Tp# 14 < [16] 3983H SID 0x01 1:0:1:1:2:0:BAD0F8F:0:0:0: SNR = 8.0 /> < Transponder SNR =['8.0db'-Locked], LNB Power = 88.08 > < 'DVB-S2 8PSK 3990V / 5000 / 3/4' > Tp# 15 < [17] TBC 1:0:1:1:1:1:BAD8F96:0:0:0: SNR = 10.23 /> < [18] VIVAX 1:0:1:2:1:1:BAD8F96:0:0:0: SNR = 10.23 /> < Transponder SNR =['10.23db'-Locked], LNB Power = 79.82 > < 'DVB-S2 QPSK 3991H / 1667 / 4/5' > Tp# 16 < [19] Telerama_Ecuador 1:0:1:1:1:1:BAD0F97:0:0:0: SNR = 7.6 /> < Transponder SNR =['7.6db'-Locked], LNB Power = 79.82 > < 'DVB-S2 QPSK 4018H / 27538 / 3/4' > Tp# 17 < Transponder SNR =['8.89db'-Locked], LNB Power = 88.08 > < 'DVB-S2 8PSK 4022V / 5000 / 3/4' > Tp# 18 < [20] TV Pajucara Movel 1:0:C0:1BD8:DE:DE:BAD8FB6:0:0:0: SNR = 10.21 /> < [21] TV Pajucara HD 1:0:1:1BC0:DE:DE:BAD8FB6:0:0:0: SNR = 10.21 /> < Transponder SNR =['10.21db'-Locked], LNB Power = 87.16 > < 'DVB-S2 QPSK 4040V / 23333 / 4/5' > Tp# 19 < [22] TCM HD 1:0:1:A:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [23] TOON E HD 1:0:1:B:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [24] CBS 1:0:1:C:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [25] HGTV 1:0:1:D:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [26] Food 1:0:1:E:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [27] Travel 1:0:1:F:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [28] Discovery 1:0:1:10:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [29] Nick 1:0:1:11:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [30] ESPN U HD 1:0:1:15:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [31] ESPN HD 1:0:1:16:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [32] ESPN 2 HD 1:0:1:17:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [33] ESPN SEC HD 1:0:1C:18:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [34] CNN HD 1:0:1:19:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [35] CruiseSat Live 1:0:1:1B:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [36] ESPN SYN 780 1:0:1:C8:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [37] Rai Italia 1 HD (NTSC) 1:0:1:12C:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [38] CE_RTL 1:0:1:12D:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < [39] TVEA HD 1:0:1:15E:1:1:BAD8FC8:0:0:0: SNR = 10.24 /> < Transponder SNR =['10.24db'-Locked], LNB Power = 89.00 > < 'DVB-S2 16APSK 4092H / 11441 / 5/6' > Tp# 20 < Transponder SNR =['1.94db'-UnLocked], LNB Power = 88.08 > < 'DVB-S2 QPSK 4139H / 4543 / 3/4' > Tp# 21 < [40] 4139H SID 0x01 1:0:1:1:1:0:BAD102B:0:0:0: SNR = 8.9 /> < Transponder SNR =['8.9db'-Locked], LNB Power = 85.33 > < 'DVB-S2 32APSK 4169V / 3409 / 3/4' > Tp# 22 < Transponder SNR =['555.36db'-UnLocked], LNB Power = 85.33 > < 'DVB-S2 QPSK 4172V / 1667 / 5/6' > Tp# 23 < [41] ABC TV PY BK 1:0:19:2:1:1:BAD904C:0:0:0: SNR = 13.22 /> < Transponder SNR =['13.22db'-Locked], LNB Power = 85.33 > < 'DVB-S2 8PSK 4177H / 3750 / 3/4' > Tp# 24 < [42] TV CAPIXABA 1SEG 1:0:C0:42F8:217:217:BAD1051:0:0:0: SNR = 10.43 /> < [43] TV CAPIXABA HD 1:0:1:42E0:217:217:BAD1051:0:0:0: SNR = 10.43 /> < Transponder SNR =['10.43db'-Locked], LNB Power = 76.15 > < 'DVB-S2 QPSK 4182V / 3900 / 4/5' > Tp# 25 < Transponder SNR =['555.36db'-UnLocked], LNB Power = 85.33 > < 'DVB-S2 16APSK 4509V / 6460 / AUTO' > Tp# 26 < Transponder SNR =['10.83db'-Locked], LNB Power = 89.00 > < 'DVB-S2 QPSK 4591V / 5076 / AUTO' > Tp# 27 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 91.75 > < 'DVB-S2 16APSK 4607V / 2667 / 4/5' > Tp# 28 < Transponder SNR =['9.03db'-UnLocked], LNB Power = 89.00 > < 'DVB-S2 QPSK 4611V / 2667 / AUTO' > Tp# 29 < Transponder SNR =['8.75db'-UnLocked], LNB Power = 87.16 > < 'DVB-S2 QPSK 4664V / 1310 / AUTO' > Tp# 30 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 81.66 > < 'DVB-S2 QPSK 4673V / 2455 / AUTO' > Tp# 31 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 88.08 > < 'DVB-S2 QPSK 4676V / 2762 / AUTO' > Tp# 32 < Transponder SNR =['652.35db'-UnLocked], LNB Power = 88.08 > < 'DVB-S2 16APSK 4700V / 2969 / AUTO' > Tp# 33 < Transponder SNR =['8.89db'-UnLocked], LNB Power = 91.75 > < 'DVB-S2 16APSK 4718V / 4166 / AUTO' > Tp# 34 < Transponder SNR =['9.71db'-Locked], LNB Power = 91.75 > < 'DVB-S2 16APSK 4736V / 4319 / AUTO' > Tp# 35 < Transponder SNR =['6.99db'-UnLocked], LNB Power = 89.00 > < Blind Scan Time = 13 Min. 13 Sec. 43 Channels ( TV = 42 Radio = 1) 35 of 35 Transponders Scanned.
