- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
10-05-2012 073A on mine
Various places (usually other Forums!) host them, but it would be more politic here to go straight to source
_http://www.skybox.cc/down.asp
Edit: Fortuitous that you should ask, as I've just spotted that there is an Edit Tool in the list of available Downloads.
As a matter of interest, what is the date/version of Firmware you are using, Hixxy?
Mine is 5th June (or 6th May, depending upon what Format the date stamp represents!).
I think there is a newer one from September, but the changes are chiefly re. Time Zones (Might be a fix for Analoguesat's wonky clock!! :-thumb1 )
I was getting a bit worries after flashing the file all I could see was noch on the display and a black screen, I forgot that it was going to boot in pal- need to hook it up to my old tv with composite to get it back to ntsc.
Just flashed mine also to the 20 Sep version, downloaded from the Skybox site.
Dead easy and very little smoke.
Not had a chance to see what's improved from my own point of view as yet.
I'm glad they've fixed the Favourites bug!
Oh yes - a gripe Id forgotten about - no soft power off - any press of the red button switches it off completely, then it takes what seems like bloody ages to boot as it goes through its front panel countup!
