Advice Needed 1.2m setup what now?
jase1
Vu Duo2,1.2 CM,1224 H to H 57E-30W. Sky dish.
Cheshire
Use m8x60 coach bolts, a2 stainless is best as it wont rust and stain the dish face. you can use nyloc nuts or nut plus spring washer, i think i bought mine from screwfix. Eb*y is a good place to look as well.
Many thanks, I'll give our driver a shopping list.
wod
yorkshire
jase1
Cheshire
What's the spec on the cable ill need to connect the motor to the positioner?
I'm not going to use the superjack @ the moment but depending on price I'm wondering if I should run the cable to do both. I'm looking at about 30 mtrs.
4 core for the motor. I've not even checked the jack, is it 2 core?
They are both 4 core as both work on the same principle. Two for DC supply for the motor and two for the reed sensor (pulse counter). I ran an 8-core alarm cable which does the job but I would be happier with a beefier cable. Perhaps run 2x 8-core alarm cables and double up the wires.
jase1
Cheshire
Ok, thanks for that. I might just run the one cable now and worry about the jack again.
jase1
Cheshire
I've got the 3" galv post sorted now, I think it's an old traffic light post lol. It was ok for a fiver from the scrap yard, it's about 7ft.
One thing that puzzles me is how to set the motor up. Have I got the EL version?
I was gonna set it up without the jack to start, I plan on taking this off, I'm guessing I have to swap brackets/plates around?
Mickha
North West
Setting the 1224 is quite easy, the dish just bolts to the adapter plate, which attaches to the motor using the supplied brackets.
Setting it up on the pole is even easier, as it has a lip that sits on top of the pole.
jase1
Cheshire
So it's just a case of removing the pin with the circlips in the end and replacing it wit a bolt.
jase1
Cheshire
It looks like I'm missing this, the bolt that connects the motor to the
Looks like I'm missing the threaded bar and brackets to connect the dish to the bracket on the pole......
Mickha
North West
Can you please upload some more pictures, of your motor, as the ones you've attached seem to be upside down and zoomed in too close, to see everything.
When the jack is attached you don't need the bolt, as this would stop your jack from tilting the dish.
jase1
Cheshire
image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
Heres some more photos.
I don't plan on using the jack to start with, I was going to remove it.
Mickha
North West
The seller might still have the screw thread, and parts, he just didn't need them as he was using the jack, you might want to contact him. You could still attach the jack, as a support, but not wire it up.
jase1
Cheshire
The seller removed it from a building in Manchester, I took all the bits he had.
I'm sure I'll sort something out.
