2.4 DH Antenna installation
blademedia
Sky
diameter of my Invacom ADF with a vernier caliper and it is 25.0mm
Your caliper is accurate moonbase :), no real need for a split holder with the end of the scaler screwing of, ive gone for a steel one, will weld this lot up and connect it to the aluminium holder with threaded rod, this will allow movement in every direction.
View attachment 104427 View attachment 104428
Nice one ...
Not very nice weather for outdoors fabrication matey is it, filthy wet and cold up here.
blademedia
Sky
Nice one ...
Wet and miserable here John, I have a workshop to work in so its not too bad for jobs like this :)
blademedia
Sky
I best go and buy a compass, cant find a tin the correct size :D, need to make it slightly larger than this to bolt the feedhorn too it
blademedia
Sky
Both working on same project @John :), Proto type no 2, no 1 will be ok for the precision feed, will cut them out tomorrow
Your caliper is accurate moonbase...
It's a Mitutoyo caliper with old style clock face, I got a couple of them second hand, they seem accurate enough for my bodge jobs.
Rgds
blademedia
Sky
Rgds
Its spot on :). I use the older type, I have digital one that's usefully a bit out
blademedia
Sky
The scalar ring turns too easy so put some ptfe on it, also two of the screw holes are very slightly out to accept this lnb, will run same size drill at a slight angle through holes
It appears to be Summer at your QTH ..... ;)
Either that, or your camera is predictive!
blademedia
Sky
blademedia
Sky
Picked some aluminium up for new arms and lnb holder rings, started tapping the dish arms, need to bend them next and cut them to length.
Thats a real old vice you have there got there with the quick release handle. The old tools are the best, a lot better than the modern Chinese stuff made from moderate grade steel.
blademedia
Sky
You can't beat a good old one :), I have another that's not quick realise good old vice they are will still be working when we are long gone, I need to fix this one back down I had a swap round in workshop, but nice to be working outside today bending feed arms so dragged it onto decking
blademedia
Sky
Quick, perhaps uninformed question:
Is it on purpose that the feedarm attachment points are not spaced equally around the ring-shaped part of the holder?
The angular distance seems to be 100, 130, 130, or so...
The one your quoting me on was guess work/my maths calculations and was slightly out, this ones correct
