- Mar 29, 2004
- UK
...and a small channel master 1.8...
I love it, CM 1.8m is a small dish on the farm
Rgds
Whats the price of a one day ticket to take the tour around the farm....
Free to you D, but don't come with a camera
Popped out and bought a tap and die set for collars and made a couple of rings,
You can take one of these D, which one do you want/tell me a outer diameter and I will make it, only takes a minute
Best place for collars if you want to use them is bearing boys
Shaft Collars by Bearingboys
View attachment 104990 View attachment 104991 View attachment 104992
Well, if I had a Ferrari, I wouldn't just be showing its hub caps....
Carry on.
125mm ring have any advantage over the 150mm ring?
Yes just slightly smaller than a scalar so no extra shadow when C band scalar is installed.It looks like the ring you have used with the Titanium C Band LNB fitted was the 150mm ring?
I like them collars BM so Ta for the link. Those rings look spot on, a right result there chap.
No worries J, the ring roller is a nice little tool for making things if/when you get a moment could you take some measurement's of the pro scalar, ive bought some thin ally for making a few.
And county council.You must have some very understanding neighbours.
Will do chap, i'll probably take some pics of them first to see which takes your fancy. I might get time to do it tonight cos the dragons at work, the main dish is down and there's usually nowt on the telly lol.
Thanks J no rush as and when,
The collars are lots better than the pipe clamps, one central threaded rod is enough to hold any lnb stable, will elongate bottom hole on LNB ring for left/right movement,
Decided to drill and weld collar, I will install this tomorrow,
@ D, what size ring shall I do ? waiting to finish it, I will get it done next week, ive cut and drilled lugs just need to attach them when I know what size ring
View attachment 105008 View attachment 105009
A very nice neat appearance as well ;)
...@ D, what size ring shall I do ? waiting to finish it
The holes are drilled for the support arms, unsure if I used M8/M10, if I used M10 it won't make any difference, TBH there better slightly bigger to allow movement,I think the 150mm ring will be best for me.
Did you drill the holes on the lugs for the feed support arms or for the rivets? The Precision feed support arms I have accept and M8 threaded rod, if the holes on the lugs that the feed support arms connect to could be for an M8 stud/threaded rod they would be perfect if that is an option? I can always drill them out at a later date if I need to increase the size.
Many Thx
These are the two old ADL scalar rings that i could lay my hands on at the moment. The simple one on the right was off a C/Ku servo feed unit from way back .... not sure what F/D it's designed for -- cant remember. The other conventional looking one is of a similar old age but you can see by the design of the rings that it would appear that a bit more theory and functionality went into the design compared to a modern day equivalent.
The other ring that i can't find at the moment is the same as the ones MB and Graham has i think.
blademedia,
I have an ADL scalar if you need pics or measurements of it? It came with an ADL feed barrel that accepts either a single WR229 flange or an orthomode WR229 flange.
Rgds
