Gefiltefish
Pace DS430N and Freesat HD box, 1.20 dish
Granada, SPAIN
Here in Granada, 1.3m dish and Humax HD Box. All BBC gone. Wife about to, too, I suspect when she finds out.
Analoguesat edit - map updated to here - I need a break!
buckshee
Not all bad news then !!!!
woborny
I have had a report from a client that 100x110cm dish in Polop is receiving all BBC channel fine....
joddle
Massanassa, Valencia, Spain
Here in Valencia I am still getting everything fine on my big dish - glad I did not change it when 1N started up! A few things to note though:
The Sky based channels appear to be much stronger now - in fact giving me 100% SS and 100% SQ on my Humaax Foxsat even with the attenuator in place.
The Freesat channels all appear little changed from before - i.e. now getting about between 85% and 95% SS and close to or actually 100% SQ which was never the case before.
Once things have settled down - I might try rigging up the 1.2 PF dish to see what it picks up. I had been hoping to take it down to Javea to use there on by folks villa but maybe its going to be too small for there now!!! Any Javea reports please!
buckshee
BBC1 HD, BBC2 HD, BBC3 HD all gone walk about here.
1.9M dish, Humax HDR
190cm dish:
10744 = 80% S 70% Q
10773 = 80% S 70% Q
10788 = 80% S80% Q
10803 = 80% S 70% Q
10817 = 80% S 60% Q
10847 = 0%
10862 = 80% S 70% Q
10876 = 80% S 60% Q
10921 = 80% S 70% Q
10935 = 0%
After a complete install ALL the above can be received.
190cm dish:
10744 = 80% S 70% Q
10773 = 80% S 70% Q
10788 = 80% S80% Q
10803 = 80% S 70% Q
10817 = 80% S 60% Q
10847 = 80% S 65% Q
10862 = 80% S 70% Q
10876 = 80% S 60% Q
10921 = 80% S 70% Q
10935 = 80% S 70% Q
Menorca Man
Sky+ HD (2GB Amstrad DRX890) + Generic 1.65m x 1.5m offset with Opticum LQP-04H Quad LNB
Ciutadella de Menorca
Looks as if 2E has replicated 2F's hotspot around Valencia, along with the sharp null over Cataluña and the Balearics.
Bazzer
1.9m of unknown manufacturer
Newish Invacom quad
Sky Box
Javea, Costa Blanca, Spain
BBC rock solid in Javea on a 1.9
woborny
Early indications are that looks like it will be borderline...
But not as hot.
2F uk beam is still fine on my 80cm dish.
whereas
2E uk beam is just peeking thru on the 90x100 (1m) dish)
woborny
But not as hot.
whereas
Interesting. in the last 5 minutes, all 2E uk beams have now appeared on the 80cm dish! Signal slowly rising!
davidcmadrid
40cm offset 19e, 1.5m 28e 1.2 M motor vu+
Madrid Spain
Here in Madrid i note 2E UK spot a fraction weaker than 2F overall though Madrid is a hotspot relatively speaking for 2E as it is for 2F. a 1.2m dish has rain margin. Will check periodically to see how it gets on over 24 hours.
Chaomino
80cm dish Astra 19.2e + Hotbird 13e - Vu+Solo
Galicia
Anyone have reports from the North (Galicia, Asturias,Leon)?
Yes, Polop will be fine on 110cm dish. But no headroom. Power level is rising now. Some transponders now possible on 90cm dish.
90cm dish:
10744 = 7.49 dB
10773 = 7.10 dB
10788 = 3.51 dB
10803 = 7.39 dB
10817 = 7.96 dB
10847 = 0.00 dB
10862 = 0.00 dB
10876 = 7.11 dB
10921 = 7.60 dB
10935 = 0.00 dB
Anything above 7.50dB watchable, but with occasional pixeling.
Graphing signal in real time on my site using a 1.8m dish and Vu+ Duo.
http://satellites-xml.org/print-signal-graph-last-24-hours.php
sparkyinspain
1.4 dish
invacom lnb
Humax Foxsat HDR
Murcia Spain
All BBC channels still on here in southern Spain (Mucia)
Signal level still rising. Almost at 2F level now.
Screen grab of Astra 2E, BBC News, 10818V, using 90cm dish and Vu+ Ultimo.
woborny
Yep - the 80cm dish is getting the 2es as well as the 2fs.
So is this a daily variation (like 2d had) weak at night and strong during the day....
so now to monitor it during the evening and night to see when the cut off point is!!
t the 80cm dish is getting the 2es as well as the 2fs.
Problem transponders on smaller dishes are going to be 10729, 10773, 10847, 10862, & 10921 as there is heavy interference from Badr5 on these frequencies. Dishes above 110cm don't seam to suffer so badly from this.
Does that mean that Carole Kirkwood will deliver the Weather Forecast in Arabic?
Hug
Pace Sky+ V2 (Samsung 120Gb(wonky) Hard Drive upgrade), Gibertini dish 1.3M, inverto black quad lnb.
Windows 7 Pro, Intel Q9550@ 3.8Ghz, 6Gb OCZ ReaperHPC, AMD6870, Samsung F1 500Gb,Corsair TX750 PS
Andalucia
Andalucia (Gaucin) here, all BBC + local(scotland,etc) +radio gone, good job my raspberry pi can get them all :)
If any peeps want to chat about my solutions shoot me a msg , this is all free knowledge not selling owt.
