Astra 2E: Scandinavia & Baltics Reports
4wd
Getting the picture
5 W, 9-13-19-28 E
^^^Thanks, as written earlier I tried, but can't figure anything out from the charts, on my testing receiver (which got a good linear measuring, %'s continue below picture lock) 2F uk goes from around 85% midday to 10% evenings. Dish alignment etc does nothing, signal just goes away, I could as well have been located in Moscow for some evening hours. Anyway, no problem, only channel I'd use from 2F is BBC 4 hd.
2E uk has an evening drop as well but just slight, stays well within lock apart from just a few days so far this year (weather?).
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
This is my theory. In Finland I see different variations depending on which satellites I'm looking at and also at different locations in Finland.
Satellite A reception cuts out at some point during the daily cycle whereas Satellite B keeps a decent lock.
skomedal
This and that
thule
Spot on explanation timo:)
If you hover the mouse on solid dots as provided in charts you can see the variation/wobbles that affect fringe.
Regards
4wd
Getting the picture
5 W, 9-13-19-28 E
4wd
Getting the picture
5 W, 9-13-19-28 E
2e uk in good shape here. Apart for a few evening 'beyond reception' scares it's been very stable.
Currently am particularly happy for having ITV4, the Isle of Man TT programs. Great :O)
mr420
DM8000HD . Vu+ Solo HD
T90 1w 5e 13e , Triax 110 + Inverto Black Ultra Quad
Drammen , Norway
Some of FTA channels has moved to Astra 2E Uk beam ;( That is causing problems here in Norway Drammen area. I get channels on 11390 v 2/3 27500 on evening. SNR is 4.8db -27 % guess that to low. BBC and ITV SD channels are 6db. I have Triax 110cm with maxium 0.2 db quad lnb. it many years old . Will it help with inverto LNB or Opticum Premium Quad LNB 0,1db ? Or do i need bigger dish ?
Dont want to buy big dish :(
Whilst a new lnb may help there is absolutely no substitute for more metal collecting the transmitted signal.
And to get decent rain fade allowance you may need to go up 2 or 3 dish sizes.
mr420
Drammen , Norway
I will first try new LNB but will wait maybe channels are moved back to European beam. These are Asian News channels noting to do on UK beam :)
Btw how big dish u use to get 36e ? Do u get all channels ?
Dont hold your breath for the Indian channels to move onto Europe beams. Which channels are you parrticularly interested in - they may be available elsewhere.
A battered old 80cm dish for 36E - I get a handful of channels (Im currently getting 7 or 8)
mr420
Drammen , Norway
Not available else where. I am looking for ARY News and Dunya News which has moved to 2E UK Beam.
Sorry i mixed 36e with 38e. I am interested in 38e
4wd
Getting the picture
5 W, 9-13-19-28 E
...is something around 10 meters considered big? ;O) see http://flysat.com/paksat1r-beam.php
Someone on the forum may tell if it's possible at all in Norway.
About 28.2, do try some different lnb's and adjust the setup, signal may improve by a few %'s which may be enough to keep a lock on some channels. Don't expect miracles. My experimentations with 28.2, with some luck and finetuning am gaining a few %'s of improvement\quality chosing some lnb over another, but very small fish compared to what a large dish does.
Nalleman
Motala Sweden
Sweden
Very bad reception of 2G UK-beam right now. The verticals are very very low (they are usually the strongest). 11053 H breaking up.
Might be caused by the activation of 11082 H and 11112 H on the European beam? Maybe I ought to try some skew adjustment.
mr420
Drammen , Norway
I have friends with 120cm but they have less signales than my :) And all quality 120-125 dish are expensive to. Will try with new LNB hope that helps else must get new dish and better place to install
4wd
Getting the picture
5 W, 9-13-19-28 E
open view to the sat ...and almost as important: easy to reach for adjustments! Good luck.
archive10
If you need to, try the inverto black ultra or the opticum.
They also work very well with a larger dish, so no money wasted... :cool:
mr420
Drammen , Norway
Thanks will try :)
mr420
Drammen , Norway
Just ordered Inverto Quad Black Ultra IDLB-QUDL40 0,2 dB from HM-SAT lets hope that will help :) B
mr420
Drammen , Norway
Got Inverto Quad Black Ultra delivered today from hm-sat . Getting 2-3db more than my old LNB . Have 97% signal's on some channels.
Will do some more tests in coming weeks :)
