4wd
Getting the picture
- Dec 16, 2012
- 5 W, 9-13-19-28 E
- Bergen, Norway \ Alpes Maritimes, France
Yes, but if you "over-drive" your receiver it may looks like the signal levels are low but it may cause intermodulation (interference) due to some very high signals
Hello, I can understand that a very strong transponder could overdrive some receivers, but am refering to BU failing early with the 'next to nothing' levels I get from 28E UK in the evenings, there is sometimes nearly nothing to amplify :O) Let alone overdrive anything (as far as I can understand...)
The Maximum xo-11 I have refered to gives some good Q %'s + a picture at very low sat signal strength, it's at those very minimal sat levels the BU quad does not perform well here, while the xo squeezes out a stable picture long after the BU had given up. Got basically the same result testing different Triax & MTI quads, and some other singles, that single xo-11 always the best so far on this particular setup
