M60
Northern England
What I heard and posted about 2F's plans was from a trustworthy industry source, obviously due to confidentiality reasons I can't disclose who and where but wanted to let you all know what I've been told.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hello solly,
please compare 43.5°E (Astra 2F Test Position) <-> 42.0°E (Türksat 3A).
Best regards
qwer.
how it back 3 transponder
11778v
11625v
11650v
dx qwer
Rastatt/Germany
I cannot confirm those 3 transponder (from Astra 2F).
Edit: As I can see in your attached file, solly, you get no peak on 12188 H (from Astra 2F), which is active at this moment.
easydigital
Sweden
Motorised 120cm dish,
VU+® Solo² Full HD 1080p Twin Linux PVR
VU+ UNO HD Receivers
Titanium Twin LNB TT 0.1dB
Inverto Black Ultra 0.2dB
Stockholm
Astra 2F at 43.5°E
_http://www.lyngsat.com/Astra-2F.html
Black Hole Vu+ Uno 1.7.8
The beams listed are complete guesswork :D
Kasper17
I have Skystar 2, Core i5:3.2Ghz, HDD:500 GB, DDR3 2Go...
Algeria
I think SES is testing the UK spot beam right now ...
This is what I got from the last scan,
it seems that it has the same frequencies of 1N UK spot beam but with a very weak signal.!!?
skomedal
This and that
thule
0N - 0E
According to these co-ordinates they are from somewhere in the atlantic just south of the coast of Ghana and west of Gabon sometime called the Gulf of Guinea
it look pick signal like morning
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
0N - 0E
OH MY GOD they are testing ´2d´ freqs on the WEST AFRICA BEAM - were all doomed in TENERIFE !!!
Hixxy1
East Midlands
what sky on demand in spain ?? but without the PSB i would think??
That's if you know how to bypass microsoft silverlight.
I've tried it myself and couldn't get it to work through a software proxy.
However this website works well for streaming the freeview channel for free.
_www.tvcatchup.com
skomedal
This and that
thule
Thats if you look closely at the thumbnail co-ordinates in post 415
terryashbyash
skybox F3 for fta/28.2E
inverto black ultra lnb
1m offset
Gandia, Spain
_www.tvcatchup.com
I prefer filmon website as freeview SD channels are free, If you sign up you can record programs again for free(you need to download the hd player from downloads section) and you do not need a proxy or to make changes to pc config. N.B For recordings to work the player(sign in on player once then close it) must be installed but just use the recordings section of the website for playback or watch live.
My first choice when weather wipes out satellite signal for me.
BLUEPLATINUM
Maspalomas, Gran Canaria
_www.tvcatchup.com
It does work (inc. PS:cool: at present with big dish and if Sky go onto 2F pan-european beam should work on a small dish. I have VPNUK configured in my router, but I did see a report from Sweden that it works without changing your IP.
now test 12516h
10870v low signal 1db
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Funny that everyone seems to know when it's the UK beam and when it's the PE beam ;)
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
_www.tvcatchup.com
tvcatchup - you have it working in spain ,thats interesting can you pm me how you do that ??
andrewcrawford
scotland
ive been wondering how they can tell which beam it is, because the beams will have been moved off axis to the east so unless someone has took the beams maps and moved them to what they look like east of it final position so they can get a power reading for a dish size
