Being not a specialist or anything when it does move anyone any ideas what size dishes we will need in Tenerife for BBc1 throught to channel 5 ? and will it effect sly sports. Thanks in advance.
For the PSB channels no-one knows. You may find things are much as they are now.
However I suspect you will suffer interference from the enhanced coverage west african beam if SES do frequency re-use between the UK & West Africa spots.
Its all guesswork at the moment - we just dont have enough information.
The widebeam stuff should stay more or less as it is atm
sorry you being an expert and all that ,but what do you mean by interference from WAB ??? if its 3000KM from UK to TENERIFE and only 1500km from DAKAR to TENERIFE you just wont get UK BEAM but nice and strong GHANA TV .... not being picky but lots of ppl are asking and best to get the point out there .
2F won't be active in Nov, it's going to start moving in Nov but 1N will still be active and in full use at 28.2E for another Month at least. As for when it goes in to full service at 28.2E I honestly can't say as I'm not privy to that info but any speculation that it will be in service by the 15th Nov is not true!
We are only assuming SES will reuse the frequencies on the UK & WA spots. I think there will be reuse eventually, but its not been confirmed.
I agree with you TTV that when the WA beam is lit up The Canaries are very likely to lose any chance of getting uk PSB channels direct via 28E - and that may well come to pass when 2F takes over from 1N anyway if the south westerly drop off of the beam is as sharp as we expect
We do know SES will be expanding coverage into WA from 28E both with more frequencies (on two of the new birds) and wider coverage area - thats public knowledge
Perhaps our CI expats can persuade Ghana Channel One to show Eastenders
nothing is truly fact..... what happens when it gets to postion and people in your area cant get pe beam on 60cm due to slight problem on the dishes???? and requires a bigger 1m dish??? you are speculatinga little and using press release for the rest until its in postion no one knows for sure not even ses themselfOK while we are waiting,lets go and be mr Holmes
FACT UK BEAM WILL USE ´´2d ´´ FREQUENCIES
FACT PE BEAM ON 60cm DISHS HERE
FACT EUTELSAT 28AFIXED BEAM ON 1M DISH HERE
FACT THREAT OF ´FRU´WILL STOP ANYONE BUYING BIGGER DISH
Even if we lose the PSB channels we will have the programming on catch up through Sky On Demand and because it downloads there won't be any streaming or quality problems. (Assuming the Sky On Demand "control signals" are on PE beam)Perhaps our CI expats can persuade Ghana Channel One to show Eastenders
what sky on demand in spain ?? but without the PSB i would think??Even if we lose the PSB channels we will have the programming on catch up through Sky On Demand and because it downloads there won't be any streaming or quality problems. (Assuming the Sky On Demand "control signals" are on PE beam)
