Eutelsat Hot Bird 13F & 13G
rodscha
in e2 you have to use a utility/tools dvb-ip-mpe2ts
root@ustym4kpro:~# dvb-ip-mpe2ts -h
Usage: dvb-ip-mpe2ts [OPTIONS]
dvb-ip-mpe2ts v0.7a 22/11/2018
Extract ts-file:
-i,     DVB-IP-MPE TS input file ('-' for STDIN)
-o,     extracted TS output file ('-' for STDOUT)
-p,     pid to be processed
-a,     destination IP-address, e.g. 127.0.0.1
-n,     destination port, e.g. 3000
Scan file for pids, destination IP-addresses and port:
-s,     number of valid TS packets with pusi to be scanned in DVB-IP-MPE TS input file, e.g 100
Help:
-h,     print this help
Examples:
dvb-ip-mpe2ts -i inputfile.ts -o outputfile.ts -p 200 -a 127.0.0.1 -n 3000
dvb-ip-mpe2ts -i inputfile.ts -o - -p 200 -a 127.0.0.1 -n 3000 > outputfile.ts
cat inputfile.ts | dvb-ip-mpe2ts -i - -o - -p 200 -a 127.0.0.1 -n 3000 > outputfile.ts
dvb-ip-mpe2ts -i inputfile.ts -s 100
root@ustym4kpro:~#
thank you! I don 't feel being able to do this now. If this encoding becomes common place,I'll have to learn it.
13.0E_11315 V,27500,3/4,8PSK has several pids, only one, which changes, is active. That's why it's on 224.31.5.2 now. Yesterday, it was on 224.31.5.6.
It's a radio stream, from which only audio "crackles" come out.
EnoSat
enosat.euweb.cz
Slovakia
e.g.
wget http://127.0.0.1:8001/1:0:1:3F4:321:13E:82AC5B:0:0:0: -q -O- | dvb-ip-mpe2ts -i - -o - -p 1012 -a 224.30.3.10 -n 6000 2>/dev/null
italy2006
starsat
iran
some adult tv moved to weakest transponder 10719. really bad news for fringe regions.
Harsh though it is your complaints are irrelevant to both the satellite operators & the tv channels. You are well outside the intended delivery target AND you arent paying millions of Euros every year for the transmission.
Make ther most of what you can get now - in 20 years from now satellite delivery of tv channels will be in severe decline in many areas of the world.
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Westport 53.81N,-9.54W
The frequency with test channels is active again:
Transponder: 10950 V 27500 DVB-S2/8PSK 2/3
During last month, the inactive Hotbird 13E moved a bit (and stable now) to 12.8°E.
italy2006
starsat
iran
viacom bulgatia
• Eutelsat Hot Bird 13G (13°E), freq. 12.616 GHz, pole H, SR 30000, FEC 5/6, DVB-S2/8PSK
• Eutelsat Hot Bird 13F (13°E), freq. 12.634 GHz, pole V, SR 30000, FEC 5/6, DVB-S2/8PSK
• Eutelsat Hot Bird 13G (13°E), freq. 12.654 GHz, pole H, SR 30000, FEC 5/6, DVB-S2/8PSK
• Eutelsat Hot Bird 13G (13°E), freq. 12.673 GHz, pole V, SR 30000, FEC 5/6, DVB-S2/8PSK
• Eutelsat Hot Bird 13G (13°E), freq. 12.713 GHz, pole. V, SR 30000, FEC 5/6, DVB-S2/8PSK
italy2006
starsat
iran
too strange. why these channels arenot receivable in middle east?
The sybmol it 30mb not 27 5mb
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Hi, today I had the opportunity to try out these new frequencies and surprisingly I don't have any signal here in the Azores, the rest of the Hotbird frequencies I can all get a good signal above 12db
jsda30
edision os mio 4k
spain
here the same in canary islands
all tps good signal vivacom not
italy2006
starsat
iran
it seems eutelsat can design specific beams according to provider request. this feature is availble in hotbird f and g.
I did point out many times in the initial discussions of these satellites there was a "superbeam" on the new Hotbirds listed in the specs Id seen somewhere - but no one believed me...... Looks like I was right :cool:
The new Bulgarian muxes are definitely lower signal strength here than the other frequencies. Not by much but they are definitely down a bit.
All five transponders are on Hotbird 13F and the uplink is managed by eutelsat.
Regarding signal quality, it must be kept in mind that with modulation 8PSK and Fec 5/6, the minimum reception threshold is quite high, around 9,4 dB.
Fisty McB
See my signature...
County Tyrone, N. Ireland
No problems with reception here in Northern Ireland, indeed the SNR seems to be stronger than the other transponders I get here from 13E, up to 1.5db higher than normal!
I take it Vivacom are in the process of moving from Intelsat 38 @45E to Hot Bird?
Nalleman
Motala Sweden
Sweden
The Bulgarian muxes are at the same level as the other transponders on 13 F/G in the southern part of Sweden which means a very strong signal (around 17,5 dB with an 1,1 m antenna).
duck77
Azores
