Is there CAM to get skytv on DVB-S tuner card?
daveyboyc
Enquiring about setup using multiple satelitte a dvb-t tuners
london
Just got my B/band connection back aftera couple of hours 'O'-red
Have you tried it with box id set to auto (boxid=0 in the NDSCam ini file)? That's how I have it, at least it should find the non-premium channels (I don't have any others).
In fact, if I put my box id in, I occasionally have the problem you describe.
daveyboyc
london
Yeah i have, its already set at 0 as default.
daveyboyc
london
Still nothing - "cant receive EMM packets !, the error appears as the EMM PID is missing, no DCW present" what the hells wrong with it? :(
daveyboyc
london
what version of softcsa should i be using?
Here's my NDSCam log using a freesat card opening up FIVE (normally FTV only). I don't have access at present to my subs card.
As you can see, EMM packets aren't received, but the channel opens anyway.
19:57:12.859 |//////////////////////////////////////////////
19:57:12.859 |// NDSCam ver. 0.0.0.7 by Joker
19:57:12.859 |MD-API Version 01.02
19:57:12.859 |TT-tricking OFF
19:57:12.859 |Auto baud rate detection ON
19:57:12.859 |BoxID auto detection ON
19:57:12.859 |Phoenix reader selected in port COM1.
19:57:14.500 |Host is changing the channel.
19:57:14.500 |Restart requested.
19:57:14.500 |PMT filter started at PID=277 (0x0115)
19:57:15.218 |Stopping PMT filter at PID=277 (0x0115)
19:57:15.218 |CAT filter started at PID=1 (0x0001)
19:57:18.140 |Opening COM1.
19:57:18.140 |Reseting COM port.
19:57:18.328 |--------------------------------------------------------------------------------
19:57:18.328 |	  >> Reseting card and analyzing ATR <<
19:57:18.328 |Inverse convention detected.
19:57:18.375 |GLA card detected. | Card ID:GX28-1B or GX28-2B | Chip manufaster:SLE | Chip ID:SLE66 | MCU:80C51
19:57:18.375 |ATR: 3F FD 13 25 02 50 00 0F 33 B0 0F 69 FF 4A 50 D0 00 00 53 59 02
19:57:18.375 |ATR length 21(0x15) bytes.
19:57:18.375 |Initial character: 3F
19:57:18.375 |Format character: FD
19:57:18.375 |Interface characters:
19:57:18.375 |TA1:13
19:57:18.375 |TB1:25
19:57:18.375 |TC1:02
19:57:18.375 |TD1:50
19:57:18.375 |Protocol : T=0 (first offered)
19:57:18.375 |TA2:00
19:57:18.375 |Protocol : T=0 in specific mode
19:57:18.375 |TC2:0F
19:57:18.375 |Historical 13(0x0D) bytes:
19:57:18.375 | 3  °     i  ÿ  J  P  Ð        S  Y
19:57:18.375 |Parameter bytes: Fi=1 Di=3 II=1 Pi1=5 Pi2=0, Guardtime N=2
19:57:18.375 |External clock used, Max FS= 5.000MHz, F=372, D=4.00, Max I=50mA, Vpp=5V
19:57:18.390 |Settings for card:
19:57:18.390 |Clock: 5.000MHz ETU: 18600µs Baudrate:   53763bps
19:57:18.390 |Clock: 4.500MHz ETU: 20667µs Baudrate:   48387bps
19:57:18.390 |Clock: 4.000MHz ETU: 23250µs Baudrate:   43011bps
19:57:18.390 |Clock: 3.571MHz ETU: 26042µs Baudrate:   38400bps
19:57:18.390 |--------------------------------------------------------------------------------
19:57:18.390 |Changing COM port settings.
19:57:18.437 |Additional setup: 3:0:0
19:57:18.437 |Initializing card ...
19:57:18.546 |Searching for BoxID.
19:57:18.875 |Error: Can't receive EMM packets ! This error appears if EMM Pid is missing.
19:57:31.781 |Host is changing the channel.
19:57:31.781 |Restart requested.
19:57:31.781 |Stopping CAT filter at PID=1 (0x0001)
19:57:31.796 |PMT filter started at PID=257 (0x0101)
19:57:32.281 |Stopping PMT filter at PID=257 (0x0101)
19:57:32.281 |CAT filter started at PID=1 (0x0001)
19:57:32.750 |Host is changing the channel.
19:57:32.750 |Restart requested.
19:57:32.750 |Stopping CAT filter at PID=1 (0x0001)
19:57:32.750 |PMT filter started at PID=257 (0x0101)
19:57:33.234 |Stopping PMT filter at PID=257 (0x0101)
19:57:33.234 |CAT filter started at PID=1 (0x0001)
19:57:36.156 |Restarting using: ChName=FIVE (NAR), SID=7700 (0x1E14), LNB/DiSEqC=6, CAID=2400 (0x0960) NDS, ECM=1280 (0x0500), EMM=0 (0x0000), CA Count=9
19:57:36.156 |ECM filter started at PID=1280 (0x0500)
19:57:36.156 |Can't receive EMM packets !
19:57:36.718 |ECM packet received in 0563 ms.
19:57:36.906 |DCW NOT processed.
19:57:36.906 |DCW not precent.
19:57:36.906 |Process took 0187 ms.
19:57:37.625 |ECM packet received in 0906 ms.
19:57:37.796 |DCW not precent.
19:57:37.796 |DCW NOT processed.
19:57:37.796 |Process took 0172 ms.
19:57:44.609 |ECM packet received in 6984 ms.
19:57:44.781 |DCW NOT processed.
19:57:44.781 |DCW not precent.
19:57:44.781 |Process took 0172 ms.
19:57:54.015 |ECM packet received in 9407 ms.
19:57:54.187 |DCW not precent.
19:57:54.187 |DCW NOT processed.
19:57:54.187 |Process took 0172 ms.
19:58:00.984 |ECM packet received in 6968 ms.
19:58:01.156 |DCW NOT processed.
19:58:01.156 |DCW not precent.
19:58:01.156 |Process took 0172 ms.
19:58:04.109 |Main application is trying to unload NDSCam.
19:58:04.125 |Stopping CAT filter at PID=1 (0x0001)
19:58:04.125 |Stopping ECM filter at PID=1280 (0x0500)
19:58:04.578 |Closing COM1 port.
19:58:04.578 |//////////////////////////////////////////////
19:58:04.578 |// NDSCam stopped.
daveyboyc
london
what log? - i think you might have forgot to post it.
Do yuo think it might have anything to do with the version of NDS/softCSA i have downloaded? i have SoftCSA 300. Should the MDplugins be in the dvbviewer root folder? could you suggest what setting phoenix mode should be on?
Really apprecitae the help.
daveyboyc
london
can see the log now. still dont know how to work this thing.
Check my post again. You were too quick for me, yes I didn't upload the log :-doh2
daveyboyc
london
Still cant get it to work )(-red
Could it be the card reader - or is it working if it has detected the card? sometimes cas studio doesnt connect to the device and i have to unplug and plug it in again to get it to start.
Does softcas need to be set to "decode all" - what version are you using? - if i use the same versions and settings that you have and you can get it to work and i cant, then it can only be the card reader or the card i guess.
Can't see it being the card reader, that's just a dumb terminal. Your card is being read, so NDSCam is working. I'll check my version of SoftCSA, I'm sure it's version 300 like yours. Also I'll check the file placement and see if it tallies with yours. . When I can get at the PC they're on - the room's out of bounds ATM - Hoovering in progress :-doh2
daveyboyc
london
Thank you so much! if you could help out in anyway id really appreciate it.
OK, as I have SoftCSA-300, the folders inside, MDPlugins, Plugins and the three .dll files are distributed in my DVBViewer as follows -
[1] MDPlugins folder in DVBViewer's root directory. NDSCam.dll, NDSCam.ini and NDSCam_logs go inside MDPlugins.
[2] Plugins folder in DVBViewer's root directory. In this folder are already SoftCSA.ini and SoftCSA.dll.
[3] The three .dll files that come with SoftCSA-300 (CSA.dll, FFDecsa.dll and MakroCSA.dll) go in DVBViewer's root directory.
If yours are already as shown, I can't think what's preventing it from working.
daveyboyc
london
still not working.. what version of dvbviewer are you using?
I'm using the latest version of DVBViewer Pro (4.5.0.0).
daveyboyc
london
thats the same version i have :confused
So you dont think it could be the card reader? that and the card are pretty much the only differences between my setup, yours and kuch kuch.
Would've thought the card reader would be similar to the one in my CAS3+ as they are both Duolabs and use Duolabs' CAS Studio software. In any case, as it's Phoenix compatible and is reading your card it's unlikely to be the cause of your problem.
daveyboyc
london
Ok, so by the logs, the card reader is doing what it is supposed to? would it not be worth try the something like cas3+ or infinity?
So so you think it could be the card? Didnt kuchkuch get it to work on a similar card? + you can get stuff like discovery whereas i cant..
daveyboyc
london
when you use cas studio, do you just go to utilities and set it to phoeniex 3.87 , press hide and thats all?
That's how I have it. Got to be something wrong or missing in the decryption process. Need some time to think about it.
