Is there CAM to get skytv on DVB-S tuner card?
I didn't recommend them, just offered them up as a potential supplier. Sorry to hear of your problem with them. May be another supplier out there, but hesitate to suggest one again :eek:
I use a Duolabs CAS3+, but may be overkill if you just need a smartcard reader, as it's a little pricey for your needs.
daveyboyc
Enquiring about setup using multiple satelitte a dvb-t tuners
london
Well im not blaming you, maybe the package will arrive. I just put it down to luck. What would be different about the one you use? can you put me in the right direction as to where i might be able to buy one?
One of our site sponsors sells the CAS3+ (Pulsat).
It also programs CAMS like the Diablo etc.
There's also the Dynamite Plus programmer from Duolabs, again available from a couple of our sponsors (Pulsat or Southernsatellite to name two). That just does smartcards.
daveyboyc
london
So how do i use these card readers? do i have to input the subscription card and install nds emulator?
daveyboyc
london
would this work well?
Ebay 200522580779
[WARNING]Don't post live links - just post the item number.[/WARNING]
Not unless you want the Diablo CAM as well.
daveyboyc
london
So the diablo cam isnt of much use then?
daveyboyc
london
so this would do:
ebay Item number:320594613050
Yes, that's the one. I assume you have a serial port on your PC.
daveyboyc
london
Yes but being used by monitor. What is exactly i need to do to get this work? Do i need to get an additional port, or can i use some sort of adapter?
daveyboyc
london
So i guess i will have to check the motherboard to see if i can add another port
Why does your monitor need to use a serial port? Does it have some kind of colour checking device or penscribe?
daveyboyc
london
Dont know mate, i thought all monitors used serial ports. Maybe its not the same kind of serail port. How else would i connect it? My pc has a HDMI slot but the monitor doesnt.
daveyboyc
london
right, ive confused serial port with vga port:mad:
I have another PC with a serial port, im actually looking to network 3 pc's together, would i be able to use the card reader through the network or would the PC(s) containing the tv tuners need the to have the card reader?
VLC is your friend for networking video/audio to your PC(s). Just need Multicast or similar on the server PC with the tuner card. May be wrong, but don't think you need TV tuners on the client PC(s). Haven't tried it with the cardreader/NDSCam setup on the server PC but can't see why it wouldn't work.
daveyboyc
london
Ok thanks for the info. Im not going to be using it to stream from pc to pc however, im going to be capturing tv on 2 pc's with their own capture cards so i guess they might both need the card readers.
Whats different about the CAS3+ and the Dynamite+Plus? How do they work with the NDS emulator?
CAS3+ uses the smart card slot in Phoenix mode, as does the Dynamite+. The CAS3+ also has the CAM slot, not used in this application of course.
daveyboyc
london
Ok, i will go for the dynamite one.
one last thing, sorry i know you gave some info eariler. but is there a particualar serial port back plate i need? i have a gigabyte motherboard (there is a COM header port on it)
thanks
Yes, the one mentioned in the previous post #28 - part no. 12CF1-1CM001-32R.
