- Mar 25, 2005
- Age
- 60
- Primesat/Famaval 1.8 PF C/ku/Ka, Octagon SX8HD1, SX88, Openbox S3 Mini HD-V8S Freesat V7 HD-V8 Finder, Amiko A4K Combo, Satlook Colour HD Spectrum, Sansui A909 Amp and BOSE Acoustimass speakers for the audio.
- Staffs UK
I'm having similar issues with it adding Ka transponders to the Ku list. Possibly with them adding Enigma2 support for the database something is corrupt...might be worth going back a few firmwares, if you still have the older versions that is.Not sure if I have a problem with the SX88 or not. Put the dish on for example 5west and all the multistream channels show 'NO SIGNAL'. With the 1.2CM the signal is of course 100%. Do a rescan and up they all pop again all added once more!. So they are there twice now.
Am I doing something wrong.???? Even if the dish isn't moved they still show No Signal when put on Standby....and need a rescan! Is it a fault? Or does it need a factory reset and the software re loading? Either way a pain!
Thank you in advance for any advice.
