I have an Octagon sx88 - Does anyone know if I buy a sound bar and connect it to the audio output socket on the Octagon 88 satellite receiver if it will produce live French sound on 5 west?
Thanks,
Mooncamm
My experience is , you will get no sound . But there is a workaround to this problem .Here is my solution , proven and it is working OK.
1. SX 88 is connected to wired LAN. I created a WLAN just to connect Samsung phone to my network
2. My outdated Samsung Trend 2 phone serves as a audio player running VLC to decode french DD+ audio.
3. Phone is connected to audio receiver ( stereo analog connection)
4.. How it works ? Select a french channel on SX88 ( eg FRANCE 2 ), open VLC apllication in Samsung, open local network , find SX 88 , it will appear as MS 192, 168 XX XXX ( local IP address) , then selcect Live TV , a list of all satellite channels on Eutelsat 5 will show , select the same channel ( eg FRANCE 2 ) and enjoy the sound comming from big speakers of your home audio. Adjust audio level on the phone
This set up works OK , not very convenient to use as you have manually change channels on your phone and on SX 88 ( it is not automatic )
My home network is wired , I use basic Asus router working in Access Point mode to create wireless connection with Samsung phone .Router is in the same room as the rest of my equipment .It is better fo connect SX 88 via Ethetnet cable to a network , I find WIFI to slow , signall drop outs and so on .
I would opt for MHL ( mobile high def link ) using USB - HDMI cable to connect phone and audio receiver instead of analog audio . My phone does not support MHL , too bad
Hope , You find it helpful or just wait for another SX88 with DD+ on board
