OCTAGON SX88 H.265 HEVC HD
I will try that,
Saved settings to USB stick
Load latest software via ethernet (SW Version 1.04.50)
Menu
Select Installation = Weather Forecast ?
Select System Settings = Weather Forecast ?
Select Media = Weather Forecast ?
Select Channel Editor = Weather Forecast ?
Select PVR = Weather Forecast ?
Select F4 = Weather Forecast ?
Press Blue button = Weather Forecast ?
Unable to find factory reset in the new menu layout :( give up back to previous software.
As a last ditch attempt I will try the same software from the link in this thread.
Same results as on line software so back to previous software,
Now Factory default & load latest patch :rolleyes: I do not think this will work either so I will stick with the latest software & avoid a Brick :cool:
I will try that,
Menu
All OK here. Something must have corrupted.
stephan94
Bavaria
Hello williams1.
I never update over the Internet (there may be problems)
Always by USB.
In your case, I think like Scopus, there is a bug.
Try to get back to a sw without problems after doing a werkreset and then try loading the new version
I hope it will work, good luck.
stephan94
Bavaria
Are there any plans to reconfigure the blind scan so that I can select the part of the Ku band that I want to scan?
Feeds on 7 East mixed with Broadcasting Channels on 7 east & 10 east feeds mixed with Broadcast channels on 9 east,
Unfortunately I do not think so, I already asked the engineers and they said it seemed difficult and unlikely.
It is true that for satellites close to each other (eg Amos and Eutelsat 5 west) it is not practical.
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
All OK here too with latest sw
Thanks for your advice stephan94 the problem that I had is now sorted :)
It would seem that while previous upgrades worked ok online without a factory reset (SW Version 1.04.50) did not,
So I followed this procedure:-
1/load patch SW Version 1.04.50 onto a USB stick
2/Save your channel list & other files to a USB stick,
3/Go to System settings & select Factory default
4/Go to Firmware update & Load software1.04.50 from the USB stick
5/Now load your channel list & other files to the receiver,
Finished all working OK :):Y
Glad it's not a Brick ..... :)
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
OTA updates will never fully wipe something, so if they have changed the config table it still use the old one which is why it was selecting the wrong things.
Glad it's sorted and you don't have a brick :D
polonez
winegard 1m.,stab hh-120,pansat 250
Poland
It looks like the TIMER LIST is gone with the newest S/W or I can't find it .
stephan94
Bavaria
stephan94
Bavaria
Once again an update
here:
Download OCTAGON_SX88_SW_EU_V10451_080318.rar (29.81 MB) now. Fast and easy at workupload.com
Octagon_sx88_v1.04.51_20180308_EU NEW SW - 08 03 2018
SW Update: Menu - Settings - SW Firmware Update: USB - Red Button : OK
English:
- ICON Menu Updated:
- Backup & Recovery Icon add.
- fixed blue button conflict problem
- Changed new menu with ICON
- Improved webtv to support age control setting
- Menu - WebTV - RED Button: set parental control - Exit and enter WebTV from New
- Added Nasche TV Plugin
- Fixed some H264 video can not decode problem (m3u8)
- Added french language
- BlindScan speed up
- Satellite Database update
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
A shame. However, it does not take too long to delete the transponders from the adjacent satellite.
It would be great when doing an individual transponder scan for the timeout to be extended to allow the receiver to lock into the lower SR ones. If I have input the parameters of the transponder manually and then wait for a lock to be achieved but when I scan to log the channels in the database, the receiver times out too soon. Alternatively, can the pids be input manually if known from Lyngsat?
mikeisyou
Feed Hunter
England
Anybody else finding that the remote control doesn't respond when you switch from a pal channel to a ntsc channel?
Fix: to unplug receiver and plug back in
mikeisyou
Feed Hunter
England
I just spoke with Octagon regarding the BBC SATBACK channels on 27.5w which currently don't scan anything on the SX88, Octagon have offered to fix this but they need the ts file I think, "need stream file with pc dvb card" would anybody be kind enough to help out? Thanks
To give Octagon credit, they do seem to be responsive to customer feedback.
Other manufacturers might do well to take note.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I found this, they seem very happy to chat on FB.
Likewise I have suggested some modifications the the SX88 Blind Scan there & received some polite replies :)
