brother9
- Sep 10, 2017
- Age
- 77
- offset Triax TD110.
- Netherlands
My new offset Triax TD110 is on Hispasat, elevation 22°.0. Much good info on this site. But everything is fixed by manufacturer: angle and length of arm, angle of LNB, focus, focal length. Finetuning elevation by degree is impossible: loosen bolts, and dish’s elevation slides UP by its weight. Adjusting declination: loosen bolts a little and with force dish jerks 5° sideways… Loosen more and dish slides down the pole… How to solve these problems?
Tuner and (HD-)screen put on roof. Dishpointer shows line parallel to edge of my flat roof, so finding satellite was easy. Got some freq., but not all, so I searched with other LNB at end of arm and got a signal on most freq…… in top right corner of dish!? What is wrong?
Readjusted dish with great difficulty, now get some 345 (mostly scrambled) stations (99% quality) on 21 freq., but NEVER a signal on 10730H27500, 10770H30000, 11422V5000, 11491V7522, 11497H7884, 12226V27500, 12303V27500, 12380V27500. What is wrong?
Advice is welcome. Tnx.
