Hellas-Sat 3 @ 39°Ε
adonis1
Also 12404V 28334 (no channels)
11078 V 3333 RIKSat left HS2
Latest Ka grab today ......
Back to making pretty patterns again, no video content as yet unless it's a mode i can't receive.
adonis1
Greek Tv multiples
(ERT HD, ERT1, ERT2, ERT3 @ Parliament TV) plus 6 radios
12223H 13383 H.264 DVB-S at 16.3 db
12241Η 13383 H.264 DVB-S at 14.6 db
Just found them a few minutes ago before I read this as this is one of my regular scans for new transponders only Vouli & ERT-3 FTA the others show as FTA but are encrypted.
adonis1
just use the same biss key with Eutelsat 3B @ 3.1° East
Yes I found that out but thanks for your reply :)
Both transponders received with equal signal quality so I assume that they are using both BSS & FSS beams for these transponders ?
No, BSS means 11.7...12.5 GHz in ITU Region 1 that includes Europe.
Also, 12223 H and 12241 H are on the same 34 MHz transponder (12232.5 H, see Frequencyplansatellites site).
Zappas204
TechniSat Digit Cl 2 receiver , 80cm dish, universal single LNB
N ot so much of a reply but a plea for some basic help please.
I believe that RIKSAT has now gone over to Hellassat 3 from 2 however I have lost contact as such I believe my LNB might be faulty, as the dish is exactly where is has always been, I get a good signal strength (62 db), but no signal quality, can anyone suggest a testing procedure please.
Welcome to the forum
Its changed frequency FlySat Hellas Sat 2/3 @ 39° East
12252V in DVB-S2 so if your receiver is sd only you wont get any signal
Zappas204
Hi Analoguesat, thank you so much for the swift reply, that is something which did not occur to me, my Digit Cl 2 is about 14 years old and has been very reliable looking at the manual it states that supports DVB not sure what D VB-S2 is or Sd, please could you explain further.?
DVB-S - the old transmission format used by standard definition digital channels for the last 20 years or so.
DVB-S2 is a new format which makes better use of the available bandwidth and is used extensively by high definition services.
A 14 year old receiver is very unlikely to support DVB-S2 so you may wish to think about replacing the receiver.
Zappas204
Thank you again I will look to purchase a new receiver then and post details when I get it.
Zappas204
The Technomates are well recommended - various members & staff here have them. Many of us have the 5402's which are excellent little receivers for not much money
Zappas204
Hi thank you for info I decided on a Technomate TM Nano SE Plus it appears to be good value what do you think.?
I prefer the non Linux Technomates as they are much easier to set up such as the TM5402HD M3,
The TM Nano SE Plus can prove very frustrating to set up due to the over complexity & unforgiving software,
That's ok if you are familiar with Linux Satellite but if you are not be aware that there is a much steeper learning curve with Linux & you will be better off with the TM5402HD M3.
Europesat
strong
Yemen
All these tps moved to Hellasat 3
12728 /12524 /12565\12606 12647/12688
And now locked successfully in Yemen
ocean04
Vaasa
Western Finland (63N 22E)
12717H has also moved to 12595H
SX88 + 100cm dish
