Hellas-Sat 3 @ 39°Ε
Zappas204
TechniSat Digit Cl 2 receiver , 80cm dish, universal single LNB
Clearly I have rubbed someone the wrong way. The initial enthusiasm that I was greeted with appears to have vanished! Ahh well ..
Not at all I can only assist you with Non -Linux receivers in the Technomate range as I am not familiar with Technomate Linux satellite receivers,
If you are unable to understand after reading the guides I suggest you contact the seller & either ask for a refund explaining why or ask for an exchange to a non Linux receiver such as the TM5402HD M3,
I hope this helps you.
Did Zappas get the receiver from one of the forum sponsors ?
Zappas204
I think so this was the link I gave them in this thread:-
SystemSAT Satellite Receivers | Free UK Delivery
Yes I did followed link provided earlier on thank you I opted for a Linux based nano SÈ m2 plus arrived today getting to know it beautifully built not easy to use but i am learning slowly.
Present hurdle is getting HellasSat 3 on list of channels as this is my satellite of interest any help appreciated. I believe need to download suitable plugin not sure how yet.
Also thank you to all here for continuing help any experts in Linux TM receivers who may care to help with above problems much appreciated.
Zappas204
No please do not misunderstand my comment i was not aware of specific personal expertise just assumed wrongly but I am learning but like anything getting help is appreciated thank you once again.
Why is Linux such an intransigent OP?
I wouldn't bother yet with any plugins, or even the particular satellite name, just get the position correct first.
Which protocol are you using to move the dish ?
It isn't.
It's just unfamiliar, until one gets to grips with it. Not difficult - just different.
It isn't.
Indeed - anyone with a Linux box will tell you that there are many times they wanted to take a big hammer to it! :D
They can be very rewarding boxes if you stick with them, but frustrating as hell at times as well.
Zappas204
It isn't.
Ok that is reassuring I am vaguely familiar with Ubuntu
Zappas204
The dish is fixed at 39 due E to receive HellasSat 2 now I need to move on to HellasSat 3 in order to receive Greek and Cyprus programs same position 39E
Fixed dish is easy then just use the link in post #151 to add the new Hellas Sat-3 transponders,
I do regular Blind Scans on this satellite & post the updates here & flysat'
FlySat Hellas Sat 2/3 @ 39° East
Zappas204
Yes understand this but Nano wil not accept manual entries needs to choose from list installed
Oh I see,
Well hopefully someone will give you a work around for this if not you can contact the seller as they are a sponsor on this site & ask for an exchange to a Non-Linux box.
I can assist you in all aspects of the TM5402HD series.
I don't believe that is actually the case, or if the preprogrammed list does fill the memory, which is unlikely, you'll be able to edit the parameters of them to match those of the new satellite.
Just how many satellites are pre-programmed in the database ?
Zappas204
There two astra and hotbird
Zappas204
[QU
OTE="Zappas204, post: 1032579, member: 411658"]Ok that is reassuring I am vaguely familiar with Ubuntu[/QUOTE]
Hi all, well managed to set up the TM Nano, at least to receive HellasSat 3 and have RIKSAT, RIK 1,2,3,and 4 as well as ERT World the Greek channel.
Now the real learning starts. May I say a big thank you to everyone here who have been very generous with their time, and help.
ERT packages have left 39 east FlySat Hellas Sat 2/3 @ 39° East
ERT is still available @ 3.1 east FlySat Eutelsat 3B @ 3.1° East
Further changes are expected over the next few days when the full transfer of Ku band transponders from Hellas Sat-2 move to Hellas Sat-3,
All European transponders will move to 12100 to 12750 in the Ku Band,
Current European transponders between 10950 to 11200 will cease on these frequencies & transferred to the higher European frequencies on Hellas Sat-3.
