- Jan 1, 2000
- Age
- 81
- The Flatlands of East Anglia
A delay in answering, apologies. I have had eye surgery recently (cataract), which renders my present reading glasses less than useful - mismatched lenses until the required time has passed between surgery and obtaining corrective lenses ( about four weeks time )LLew,
I use diseqc here without any problem. Even the combination of diseqc1.0 and diseqc1.1 works.
So you may have misconfigured sometihng. Check your lnb configuration.
Ports are numbered starting from 0. So port 4 is diseqc1.0 value 0. Make sure that diseqc1.1 is turned off by setting it to -1
and that tune string has "C" in it.
Also make sure that you do not have more than 1 lnb cnfigured for 5.0W. It is fine to do that but then both configurations
must be correct.
The log files also contain the actual data sent to the swicth, so it is easy to verify.
Unrelated: Recently I also found an old bug in the drivers, which can cause problems on streams which use physical layer scrambling.
The symptom is that tuning may be slow or even fail in neumodvb. It is fixed in the latest drivers.
I'm not sure what the diseqc problem was, as I had the correct configurations (port numbering with diseqc 1.0). I did a full reinstallation, which cured the problem.
At present, I'm attempting to do a blindscan time comparison with neumodvb between my TBS6903 and TBS6903X. With the TBS6903X, time taken to do a full H scan is about 6 minutes.
With the TBS6903, although RF/SNR levels are good when tuning a frequency, the acquired spectrum signal level is way down and impossible to effect a blindscan . The tuner is obviously working fine.
On another point, the markers on found TP's on a spectrum scan are still making it hard to read the TP info at the top of the marker despite my attempts to pan and zoom down to a level without losing the bottom of the chart. (I know you have mentioned this, is it a work in hand?).
