Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
Note that the PID is 4095 rather than the usual PID 4096. I can confirm that there is no MIS.
They changed it in the last hours. When i first scanned the frequency the PID was 4096 and in AltDvb you had to set MIS 15 otherwise it won't find any channels.
Now MIS has disappeared and the pid is 4095
MCelliotG
Thessaloniki, Greece
That's strange, Osmio which has also native T2MI only scans the regular channels, whatever pid I use. Adam can you show a screencap with your manual search parameters?
it mean 12072 move t2mi ?
Maxx@
Częstochowa
Troidal T90
Poland
Everything works fine with astra-sm :rolleyes:
(Vu+ Duo4K SE)
astra-sm
zeomis = make_t2mi_decap({
  name = "ZEONBUD TEST",
  input = "http://localhost:8001/1:0:1:1:F:55:300000:0:0:0:",
  plp = 0,
  pnr = 0,
  pid = 4095,
make_channel({
  name = "MUX TEST",
  input = { "t2mi://zeomis", },
  output = { "http://0.0.0.0:9999/zeobud/mis", },
Channel
#NAME Zeonbud
#SERVICE 1:64:1:0:0:0:0:0:0:0::TV
#DESCRIPTION TV
#SERVICE 1:64:2:0:0:0:0:0:0:0::(4.8E) 12073 H 27500 3/4  MX-1
#DESCRIPTION (4.8E) 12073 H 27500 3/4  MX-1
#SERVICE 1:0:16:B:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:UA Pershiy
#DESCRIPTION UA Pershiy
#SERVICE 1:0:16:C:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:RADA
#DESCRIPTION RADA
#SERVICE 1:0:16:D:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:1+1
#DESCRIPTION 1+1
#SERVICE 1:0:16:E:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:Ukraine
#DESCRIPTION Ukraine
#SERVICE 1:0:16:F:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:ICTV
#DESCRIPTION ICTV
#SERVICE 1:0:16:10:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:STB
#DESCRIPTION STB
#SERVICE 1:0:16:11:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:Inter
#DESCRIPTION Inter
#SERVICE 1:0:16:12:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mis:Unian TV
#DESCRIPTION Unian TV
Adam792
Cheltenham
12073H has now been changed to DVB-S2 8PSK 30000 2/3.
PID 4095 still carrying mux.1 of Ukrainian DVB-T2, plus a new PID has now appeared -
PID 4097 carrying mux.2, also in T2-MI -
Maxx@
Częstochowa
Troidal T90
Poland
Config astra-sm
zeonmx1 = make_t2mi_decap({
  name = "ZEONBUD MX-1 Test",
  input = "http://localhost:8001/1:0:1:6E:F:55:300000:0:0:0:",
  plp = 0,
  pnr = 0,
  pid = 4095,
make_channel({
  name = "ZEONBUD MX 1 Test",
  input = { "t2mi://zeonmx1", },
  output = { "http://0.0.0.0:9999/zeobud/mx1a", },
zeonmx2 = make_t2mi_decap({
  name = "ZEONBUD MX-2 Test",
  input = "http://localhost:8001/1:0:1:D2:F:55:300000:0:0:0:",
  plp = 0,
  pnr = 0,
  pid = 4097,
make_channel({
  name = "ZEONBUD MX 2 Test",
  input = { "t2mi://zeonmx2", },
  output = { "http://0.0.0.0:9999/zeobud/mx2a", },
Channel
#NAME Zeonbud
#DESCRIPTION TV
#SERVICE 1:64:2:0:0:0:0:0:0:0::(4.8E) 12073 H 30000 2/3  MX-1
#DESCRIPTION (4.8E) 12073 H 30000 2/3  MX-1
#SERVICE 1:0:16:B:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:UA Pershiy
#SERVICE 1:0:16:C:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:RADA
#DESCRIPTION RADA
#SERVICE 1:0:16:D:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:1+1
#DESCRIPTION 1+1
#SERVICE 1:0:16:E:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:Ukraine
#SERVICE 1:0:16:F:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:ICTV
#DESCRIPTION ICTV
#SERVICE 1:0:16:10:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:STB
#DESCRIPTION STB
#SERVICE 1:0:16:11:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:Inter
#DESCRIPTION Inter
#SERVICE 1:0:16:12:48:10:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx1a:Unian TV
#SERVICE 1:64:3:0:0:0:0:0:0:0::(4.8E) 12073 H 30000 2/3  MX-2
#DESCRIPTION (4.8E) 12073 H 30000 2/3  MX-2
#SERVICE 1:0:16:15:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:NOVIY-KANAL
#DESCRIPTION NOVIY-KANAL
#SERVICE 1:0:16:16:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:TET
#DESCRIPTION TET
#SERVICE 1:0:16:17:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:2+2
#DESCRIPTION 2+2
#SERVICE 1:0:16:18:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:NLO
#DESCRIPTION NLO
#SERVICE 1:0:16:19:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:NTN
#DESCRIPTION NTN
#SERVICE 1:0:16:1A:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:MEGA
#DESCRIPTION MEGA
#SERVICE 1:0:16:1B:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:Plus Plus
#DESCRIPTION Plus Plus
#SERVICE 1:0:16:1C:48:20:300000:0:0:0:http%3a//0.0.0.0%3a9999/zeobud/mx2a:Ukraina 24
#DESCRIPTION Ukraina 24
mola100
gugu
Rome
the pid's are different between config and dreamboxedit!!!
Maxx@
Częstochowa
Troidal T90
Poland
And the extra parameter is important c:150fff ,c:151001 .
You can see that you have no idea what you are writing about :(
Everything works fine :D
MX-1
MX-2
Maxx@
Częstochowa
Troidal T90
Poland
If you knew the principle of operation of astra-sm, you would not ask such questions. Pid PCR is not considered in this case and can be completely removed.
EnoSat
enosat.euweb.cz
Slovakia
nirvana
disk 150
italy
the NLO channel does not work for me
cirio70
Lombardy - Italy
It doesn't work because, if you look at the last picture posted by EnoSat, NLO broadcasts only the PMT but no Video and Audio PID are available.
stephan94
Bavaria
with the right PIDs ( 4095; 4097) all programs are visible.
you just have to enter them manually ( including in the MIO4K
which normally finds all the data by itself, but in this case it doesn't work)
jsda30
edision os mio 4k
spain
stephan94
Bavaria
EnoSat
enosat.euweb.cz
Slovakia
T2-MI pid 4096 and PLP 0 - are preset by default in E2 and do not have to be entered, if the value is different, this information must be supplied either in the form of satellites.xml or by manually entering the search parameters
etc. in XML
<transponder frequency="12187500" symbol_rate="29900000" polarization="0" fec_inner="2" system="1" modulation="2"/>
and in E2
< 1269.6606> [TuneTest] tuning to transponder with data (12187, 29900, 0, 2, 2, 235, 1, 2, 0, 2, -1, 1, 0, -1, 4096)
< 1269.6607> [eDVBFrontend0] tune
< 1269.6609> [eDVBFrontend0] prepare_sat System 1 Freq 12187000 Pol 0 SR 29900000 INV 2 FEC 2 orbpos 235 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 1, pls_code 0, t2mi_plp_id -1 t2mi_pid 4096
< 1269.6609> [eDVBFrontend0] tuning to 1587 mhz
<transponder frequency="12072720" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="2" t2mi_plp_id="0" t2mi_pid="4097"/>
< 1728.8753> [TuneTest] tuning to transponder with data (12072, 30000, 0, 2, 2, 49, 1, 2, 0, 2, -1, 1, 0, 0, 4097)
< 1728.8754> [eDVBFrontend0] tune
< 1728.8756> [eDVBFrontend0] prepare_sat System 1 Freq 12072000 Pol 0 SR 30000000 INV 2 FEC 2 orbpos 49 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 1, pls_code 0, t2mi_plp_id 0 t2mi_pid 4097
< 1728.8756> [eDVBFrontend0] tuning to 1472 mhz
