Telstar 12 Vantage.
I have a batch of channels at 11653 H (sr 6000 3/4). Any idea what they are as there should not be anything on that frequency (Express 14W has Russian on the opposite polarity but it's not that)
The 11036V Globecast OSN Backup 11036V has now disappeared from the North Sea Spotbeam.
The BBC Satback backup service now transmitting on the spotbeam on 11043V (currently coexisting with the service on 27.5W).
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
only UK beam?
Satfaca
Melmac (46N, 14.5E)
Melmac
Gents, please check these carriers and advice your location & gain, it would be to establish the beam used.
Based on my gain they are presumably either on MedEast or MedWest, however it could also be from further away (NorthSea or ME North).
I am getting these weak locks with a 2.4m in central EU (SI).
11.184 H - 11.295 H - 11.663 V
View attachment 154045 View attachment 154046 View attachment 154047
Nothing received here on those frequencies (35 miles south of Edinburgh in southern Scotland)
Satfaca
Melmac (46N, 14.5E)
Melmac
OK, it is not North Sea.
Anyone from Spain and Greece/Turkey to report?
PSK change to our disadvantage :(
^^ Please translate for those of us that have never used that software.
Try in the Constellation monitoring window at Search Range, under Frequency, to choose instead of 1 MHz to 3 or 4 MHz, that way, you have more chance that the signal will be locked, especially as 13dB on 11043 V.
No change to lock.
It has been a lockable QPSK, but it seems like the service is bundled in a data transmission now.
Cheers - it was a very strong signal here last night so when it had gone awol today my first guess was the modulation had changed away from something my little old Technomate could cope with....
No change to lock.
Also, try a hard lock, i.e., lock one of the adjacent transponders, check the Update modulation info (down left) and BlindScan, and then change the frequency to 11043 V. Repeatedly, you can also uncheck BlindScan.
If you have several cards, try them.
Probably they are testing the modulation
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
Satfaca
Melmac (46N, 14.5E)
Melmac
Bingo, thanks.
So this is MedWest (Eurospot 2) then.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
just an add-up
  • Telstar_12V.pdf
Satfaca
Melmac (46N, 14.5E)
Melmac
From the plan only 11.663 V doen't fit, planned to be on EU beam but can obviously be switched.
