- Mar 29, 2004
- UK
@blademedia
Many thanks, the feed holder ring arrived this afternoon, most appreciated.
Rgds
My C band collar turned up today,
View attachment 105354 View attachment 105355
@moonbase , when you drill it for the threaded rod drill bang opposite the grub screw, that way it only alters up/down movement not left/right
The clamps are ok ish but do have a little play, the collar holds it lots better, they do split ones but they don't come with a grub screw, so you need to get one slightly smaller too clamp round,That's a nice collar - much better than the clamps. Will nick this idea!
I know it's not really needed where the feedhorn comes away from an LNB (as in case of C band) but with normal offset LNB, you can't slide it in. Are these types of collars available in two halves anywhere? I guess I could just cut it myself but I have crooked arms and no doubt I will simply ruin it!
@blademedia
Nice work with the collars, it looks like you welded the threaded rod in place in the steel collar rather than tap the drill hole?
The universal hoolder looks good, that ring roller is getting plenty of use
Rgds
Clamps have too much play in it for my liking, like you say. Ok once tuned and tightened but not consistent.The clamps are ok ish but do have a little play, the collar holds it lots better, they do split ones but they don't come with a grub screw, so you need to get one slightly smaller too clamp round,
Bearing boys is the best place to get them
Shaft Collars by Bearingboys
@blademedia
What thickness of aluminium bar did you use for the universal collar, it looks to be around 6mm using the Precision feed as a reference? I will have a look out for a small length section of aluminium pipe to try to cut a universal collar from it.
Thx
Glad to see further progress ..... I've had withdrawal symptoms from this Topic this past week owing to being on hol without any Internet access
