Pietclock
125cm
SE Germany 50°N/11°E
yeah... any frequency can be any beam..... the fact that all UK beam were in low band is a 2D heritage...the new satellites are more flexible.
i got uk beam strong now on 2f
i never see 10964h so stronger
I think any frequency can be switched to any beam so its extremely unlikely thats the UK beam, unless the dish is slewed well east and is pointing at Israel!
Pietclock
125cm
lots of on and off switching now, I suppose they are reaching another testing phase.
Using a 3.5m dish and the peak is just 2dB above the baseline. Not what I'd call strong.
12305h very weak now
not see any signal now
the satellite it ready ?
Pietclock
125cm
what I meant is maybe they are now starting different kind of tests. That analogue carrier ist back on 12303H but much weaker than before. The wider carriers are all very weak here even with a 1.25m.
BlindFaith
TBS 5925
The term analogue carrier is misleading as well as a so called analogue "black" signal ;)
Here's a spectrum from horizontal high I did this afternoon. Left the meter on max-hold between 1pm and 3pm.
gonzobaby
100cm Gibertini OP100XL
Inverto Black Ultra Quad
Vantage HD8000S
Technotrend S2-3600
Schoeningen, Germany
a short actual spectrum from my city
Edit: i can see also the carrier on 12303H is changing his power very often...
Yes, that seems to be the one they're continually testing. On, off, 'condom' :-lmao
Horizontal-high on max-hold for last 20 minutes. Signal on 12365 H is 25 dB above the baseline.
Low band horizontal for the last 20 minutes on max-hold. Almost the entire band is active. Signal on 11515 H is 36 dB above the baseline.
Now{06:35 GMT} 12252 V is active!
You said well-"almost" but not all the band!What's so strange about these tests is the fact that I have not yet seen to make tests in subband, from 10700-10950 Mhz,so much so Astra 2F is scheduled to replace 1N.And we already know sub-band transmissions are certainly on UK spot.In fact this spot most interesting for fans in Europe. As they say, it is more interesting what you get harder than what is at hand :)
now active 12325v very strong
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
why because none of us know ses plan our potential new customers base we dnt know until it live and everything is tranfered across to it
same reason i know that the next car i buy will have an engine ?????
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
what the chance that the UK Beam will NOT be in the low band !!!!!!!
As far as I know BBC and ITV packets are transmitted on UK spot ,as before, not on PE beam.In fact for that Astra 1N replaced Astra 2D ,and now with Astra 2F,and not only that 2D completed the mission on this position.As can be seen on map,the UK spot for Astra 2F is more tight. I don't think we will have secondary lobes as was at Astra 2D.But,who knows...
I'm only joking,but British want to make from the sky a ...island :),as it shows the UK spot.
Well if you look at my screenshot in post #361 you will see it was active last night.
