Hi would it be possible to get the same transponder list you gave direct tv please??Hi, If you can let me know which 6 satellites you require and any specific Transponders, I can create a file for you if it helps?
Hi is there any way you could make me a list please??View attachment 142217View attachment 142218View attachment 142219here is the program for the USB model and for the s2 model, I myself edit and make my lists. And the letters that were from Poland on the server were my work.
Astra 28.2 astra 19 hotbird 13 and sky q if possible pleaseenter what tp you need and what satellites.
hi you can try this for now if it helpsAstra 28.2 astra 19 hotbird 13 and sky q if possible please
Hi there. Is there a way you could make a link availavle for the sortwhre where you can create your own lists? thanks in advancehello I have a program for making lists for the USB model and hd s2, if anyone is interested, please visit PW. sorry for the language I am writing from the translator.
@simat what transponders do you need I will make you a list of which satellites with tp should be included in PW.
Hej Peyu, dla ułatwienia pisze po Polsku, mieszkam i ustawiam anteny w UK. posługuje się miernikiem Horizon hdsm usb i nie narzekam i klienci również Mam wgrane satelity Hotbird oraz Astre. Tylko wszystko stare, czytam i widzę iz jesteś tutaj guru który robi czary mary i potrafi wszystko. Mój miernik ma oprogramowanie dość stare z 2011 o numerze V1. 045B czasami coś szwankuje. Tylko teraz mam prob posiadam maca czy da się przez niego jako wgrać wszystko nowe. Pozdrawiam.Ok, I'll make a list this weekend.
Hi Peyu75, have you got a link to the software plz I got HSDM v3 USB would like to have a go at making my own listshello I have a program for making lists for the USB model and hd s2, if anyone is interested, please visit PW. sorry for the language I am writing from the translator.
Has anyone found the program to make or edit the HEX files, thanks
No problem. The TPs provided with software will be very old now and not work, but will try and upload some more recent ones soon.Thanx alot cityaerials for your links much appreciated
HiGood evening Since the site is closed I am from Greece and I would like the latest satellite upgrade for the Discontinued model HDSM v2.50
thanks
Hi. Thanks for the links. Are the .pat files included up to date? If not where could I find the satellite information needed to create new ones?
Possibly notHi. Thanks for the links. Are the .pat files included up to date? If not where could I find the satellite information needed to create new ones?
