Horizon HDSM USB - Latest Firmware and software
cityaerials
Installer with horizon meter support
Coventry
hi , can someone help, i have Horizon hd s2 but from today 3/8/22 the Turksat 42e tp has changed , tried to update the tp manually but no luck
Can you confirm the frequency of the Tps with the issue? You can check in spectrum mode etc.
As a short term fix you could use custom tp option. Türksat 3A/4A at 42.0°E - LyngSat
markalmond
awilsat
london
Hi thanks for your reply ,the tp is 11096V/240 i brought this meter recently just wondering if its possible to update the tp manually.
A recent update on Flysat suggests that transponder is no longer active
cityaerials
Coventry
Hi, Unfortunately you cant update pre-loaded Tps on the HD-S2, you can only change/edit the Custom ones such as Custom1 S2, Custom1 S1 etc . Do you know if you have any custom lists loaded on meter you can try? Originally updates were loaded via the Horizon website which has now gone.
I have attached least file from horizon I have and some others that might help.
These is some third party R&D software that can create own Tps but only to list 1 and I'm informed this software can cause some issues with meter so has to be used with caution.
  • HD-S2_Manual.pdf
  • HDS2-SuperListJan2020.zip
  • Log-Reader-HLR_HDS2.zip
  • Firmware-HDS2_G_21Aa-0001.zip
  • Uk-S2HD-CustSats-List4.zip
  • custom-list4.zip
  • UK-List1-Feb20.zip
markalmond
awilsat
london
Hi , i really appreciate your efforts
cityaerials
Coventry
  • UKS2JAN-List1.zip
markalmond
awilsat
london
Hi . I'm trying to load the file on HD-S2 but i keep saying invalid data file, I'm not quite sure if the file or loader is wrong.
your help is much appreciated
cityaerials
Coventry
Hi, which file are you having an issue with?
piterus
hotbird 13B, 13c, 13e
London
Ok, I'll make a list this weekend.
Hej Peyu75, dla ułatwienia pisze po Polsku, mieszkam i ustawiam anteny w UK. posługuje się miernikiem Horizon hdsm usb i nie narzekam i klienci również Mam wgrane satelity Hotbird oraz Astre. Tylko wszystko stare, czytam i widzę iz jesteś tutaj guru który robi czary mary i potrafi wszystko. Mój miernik ma oprogramowanie dość stare z 2011 o numerze V1. 045B czasami coś szwankuje. Tylko teraz mam prob posiadam maca czy da się przez niego jako wgrać wszystko nowe. Pozdrawiam.
Mod. Note.
Please always, at the bare minimum, provide an English Translation in this part of the Forum - for the benefit of all interested Members.
I have done this for you, on this occasion.
Hey Peyu75, I write in Polish to make it easier, I live and set up antennas in the UK. I use the Horizon hdsm usb meter and I do not complain and the customers also have Hotbird and Astre satellites loaded. Just everything old, I read and see and you are here a guru who does spells and can do anything. My meter has quite old software from 2011 number V1. 045B sometimes it goes wrong. Only now I have a problem with a Mac if I can upload everything new through it. Regards.
markalmond
awilsat
london
Hi peyu75, do you managed to make a list last weekend?
satpaul
What editor are you using to update the Transponders sorry if this is already been asked
I have a HDSM and a HDSM USB both non HD
I use Setedit at moment to update satellite files
Peyu75
Prodelin 3,7m astra 28.e. UK zone
Dish 2m 90E-43W Heavy Duty 36
Poland
Piter satedit dla ciebie.
HDSM USB
  • SatEdit.rar
Peyu75
Poland
satpaul for you to :)
HAYN35
ASTRA 2
IK
hi guys i have both a hdsm usb+ and old hdsm hd-s2
my grandfather who lives in Spain needs
19.2
and 28.2
can this be sent please
