Newsnet on Ka Band A
Calibrated Spectrum in KA-Band A with self-modified GILAT LNB .
I also exchanged the quartz in 27 MHz.
regards
... did you take any pictures of the modded Gilat through the stages of work - would love to see them.
dreamsat
germany
Hey John,
I tested the first time today. When it is dismantled I take pictures.
regards
dreamsat
germany
1. Qarz is replaced by 27 MHz
2. Steam the filter
3. Install the SMA socket and attach the F adapter
4. Make the flange
Big thanks to Graham for the support
2. Steam the filter
4. Make the flange
Thanks for that, nice work. Graham (sband) was my inspiration as well with modding Gilat ODU's and helped me out a lot.
I have modded one for Band D and after a bit of careful scalar feed matching to my Gibby 1.2 found it to be a better performer than the stock Inverto Ka/Ku unit that is also being used. I did try a wr42 90°angle transition coming off the Gilat so as to make the whole unit more suitable to be made motorised for H/V use but the matching was poor and performance suffered.
dreamsat
germany
I bought an adapter. This allows the waveguide to transition much better from rectangle to round. This has a gain of the signal of about 0.8 to 1.0 dB.
best regards
I also used the same transition on one of my Gilat mods when i tried the 90° angle bend approach. I think i will pull the Gilat out of storage at some stage and have a re-think on the feed design. The small section of wr42 waveguide was put in place to accept a 40mm collar for the lnb holder. I think i will remove that and also have a look at trying to get a better scalar match.
dreamsat
germany
Hello John, where did you buy the 90 ° angle. I'm still looking for something like that.
regards
dreamsat
germany
That is not the right one. The waveguide has to be turned the other way around. (for high).
It looks in the picture almost as if you have built a waveguide cross?
We got rid of the transition thats on the actual Gilat itself by sawing off the end section of the casting and bolted straight onto the pcb. I then coated the whole assembly with plastic sealer to keep water ingress out.
dreamsat
germany
dreamsat
germany
Hey John,
do I see this correctly, that the polarity changes when you turn the LNB?
regards
Newsnet has a new screen with the ITN news music on a loop. Makes a change from looking at the back of peoples heads I suppose..Newsnet.JPG
Newsnet has a new screen with the ITN news music on a loop. Makes a change from looking at the back of peoples heads I suppose..View attachment 124442
Ooooo that's nice, i tend to still keep an eye on the floor as well as the ladies for the mice lol.
tony smith
80cms motorised mesh offset dish, ku band (Universal LNB)Technomate 5402, 1.8 Channel Master offset fixed K band lnb's 18.2-19.3, 19.2 -20.3, 1.1 Triax offset dish fixed
midlands UK
Hi Folks
Not sure if your aware, but SIS Live who provides the Ka capacity, is now finished it's been taken over by NEP Visions,
they still carry on with the Ka band contact, which has 2 or more years to run with ITV, I think the satellite side of NEP is called NEP Links.
I have seen 1 ident that has NEP in place of SIS, it's an ITN uplink I think, but the rest still call up SIS as before
Hi Folks
... Hmm, interesting. Thanks for that Tony.
Yes, first started to notice the NEP idents two or three months back..
Back, but deserted. Where is everybody :-ohmy
... new feed freq for me on 19.2° East on a very busy 18GHz band again.
18.585 V.
