I have european beam but not UK beam ?
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Since the shipping address is not linked to billing address, it doesn't matter.
jhalliday45
Setting up still bought a 125 dish for France and planning to use old Sky HD for Freesat
Cazeres
lazzaro
Vu+ Du 4K
Europe
Sorry for reviving the topic after one year.
I am interested in purchasing a Kabelio subscription. There is an activation page on their web site. Would it be enough to provide an address in Switzerland. Do they also require a Swiss telephone number?
astra19
Europe
Yes, it’s no problem. I used my employer’s address, but there’s no communications.
lazzaro
Vu+ Du 4K
Europe
Thank you for the clarification. I made the purchase.
smartcombo
VU + Zero 4K+ Offset 1.25m Motorised Dish with Vbox III Iberosat + Motor Actuator 36v and Lnb Invacom. Satellites - 28E, 42E, 13E, 19E, 26E, 7W, 30W etc..
Portugal
Is it possible to use KABELIO CI+CAM MODULE on a vu+ zero 4K
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
smartcombo
Portugal
smartcombo
Portugal
To members who say yes and others who say no. How did we stay
smartcombo
Portugal
smartcombo
Portugal
marcouk
Hull UK
I have a vu+ zero 4k. What image do you recommend putting on it to watch the channels on kabelio?
Hi AFAIK the Vu+ do not work with CI+ anymore. I myself use a Vu+ Uno 4k se running open ATV and could not get it to work with my Fransat CI+ module.
in the end I bought a cheap Technisat box for £120 for use for fransat.
smartcombo
Portugal
I refer to kabelio on hotbird
marcouk
Hull UK
Hi. the Kabelio cam is also CI+ so you will have the same problem as I had with my Fransat cam. VU+ receivers are not CI+ certified.
some of the 3rd party firmware allowed them to work for a while but now they don't anymore.
Have you received your Kabelio cam yet? if you put it in your VU+ you normally get a on screen message from the cam saying that the receiver is not compatible with CI+.
smartcombo
Portugal
I still haven't received my kabelio cam
lazzaro
Vu+ Du 4K
Europe
I have a Vu+ receiver and I am watching Kabelio.
You just have to insert the cam into a CI+ compatible receiver first; it could be your TV. I put it in my LG TV. Waited for it to clear the channels. Then inserted back into Vu+ Duo 4K. And voila!.. Works like a charm :Y
smartcombo
Portugal
I have to insert the cam and take it out and then insert the cam again
