Arabsat BADR-8
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
I also have it with Gibby 150.. please include it in the Badr 7 thread..
AhmadIraqi
StarSat , 90cm, Inverto
Iraq
Changes between 15.10.23 09:00 vs 2.12.23 06:00 Badr 4-7, 3m + SF8008
10970V 10.8db 10.8db (Badr7 NWA)
11010V 10.8db 11.0db (Badr7 NWA)
11270V 15.8db 16.0db (Badr7 EAST MENA)
11472V ----db 7.5db NEW Badr8 NWA?
11747V 9.5db 6.8db Badr5 -> Badr8 MENA
11785V 9.2db 7.5db Badr5 -> Badr8 MENA
11804H 10.8db 7.5db Badr5 -> Badr8 MENA
11843H 7.5db 6.0db Badr5 -> Badr8 MENA
11862V 9.0db 6.8db Badr5 -> Badr8 MENA
11919H 9.2db 8.2db Badr5 -> Badr8 EMENA BSS
11938H 10.8db 11.5db (Badr4)
11958H 10.8db 11.5db (Badr4)
11977V 11.2db 11.8db (Badr4)
11996H 10.8db 11.8db (Badr4)
12054V 10.5db 11.5db (Badr4)
12073H 11.0db 11.5db (Badr4)
12092V 9.2db 9.5db (Badr4)
12111H 8.2db 9.0db (Badr4)
12130V 10.5db 11.0db (Badr4)
12149H 10.5db 11.2db (Badr4)
12169V 10.5db 11.0db (Badr4)
12182H 7.0db 7.2db (Badr4)
12226H 9.5db 11.0db (Badr4)
12245V 8.5db 9.0db (Badr4)
12284V 5.2db 9.0db Badr5 -> Badr8 NWA
12303H 5.0db 8.8db Badr5 -> Badr8 NWA
12360V 6.5db ---db Badr6 -> Badr8 MENA
12456H 5.5db ---db Badr6 -> Badr8 MENA
12563V ---db 11.0db NEW Badr8 EMENA FSS
12683V ---db 3.8db (Badr4 FSS)
Summary:
- New 11472V and 12563V
- Badr8 MENA is weaker here than badr5/6 MENA
- Badr8 NWA stronger here than badr5 NWA
- Badr8 EMENA BSS is weaker here than badr4 BSS
- Badr8 EMENA FSS is much stronger here than badr4 FSS
This Freq still on MENA Beam, I receive it here in Iraq at this moment, by 110cm dish size
11472 V
DVB-S2/QPSK​
4166 8/9​
ocean04
Vaasa
Western Finland (63N 22E)
11472 V
DVB-S2/QPSK​
4166 8/9​
Flysat has it badr7 MENA, but never had signal from badr7 MENA here. 11230H has easy FEC, but nothing. Lyngsat has it bard7 NWA, but someone else said it's not that either. Also ABAANTU package, is for africa, not mena, see their homepage
AhmadIraqi
Iraq
View attachment 153156View attachment 153157
In my location (Iraq, which means in Middle East) and my dish 110cm, it is impossible to receive NWA Beam, I do not receive any frequencies from the Northwest Africa beam.
It is possible that frequency 11471 V 4166 has had its signal strengthened in Europe while its signal in MENA has been weakened.
Conversely, with frequency 11230 Horizontal 27500, its signal became strong in MENA and decreased in Europe.
The other reason is vertical polarization, the signal is often better than horizontal polarization.
Another possibility is that the frequency 11472, vertical 4166, on Badr-8 or Badr-5.
Or the frequency 11230 horizontal on Badr-5
I got an odd result today from my test scans with Badr-8.
After creating a table with a list of Badr-8 frequencies common to both Lyngsat and Flysat I measured the dB level using a Dr HD F15 receiver.
I thought I would check to see if the dish was peaked on the satellite so nudged it 0.2 degrees East and measured the dB levels again.
Three of the 16 frequencies I measured in the list increased in dB level due to the 0.2 degrees East nudge
Twelve of the 16 frequencies decreased in dB level, one was practically no change.
The table is attached below.
If anyone else wishes to try the same test it would be interesting to see the results?
There could be some anomaly at play from the beams as I am located in the UK. Some of these frequencies are fringe reception, out of beam.
Or, the three frequencies that increased are not on the same satellite as the twelve frequencies that decreased from the 0.2E nudge?
interference between Badr 8 & Astra 2(28.2East)
I had thought of that but the 2.0m dish I used does not have a very wide beamwidth and another 0.2 degrees East saw the signals that had increased reduce in level.
Also, for the 11747V (SR27500) that showed the biggest increase there is no frequency close to that in V polarity on 28.2E
danny10
Czech republik
The classic case of interference on 3W is from 4W and 5W.. you have to try which side you move the motor to..
precisely because of that...!less interference from TP..
I'm not sure about interference from 23.5E, the dish is 2.0m with a Ku-Band beamwidth of 0.93 degrees.
Interference from 2.5 degrees away on a dish that has a beamwidth of 0.93 degrees would be unusual.
I suppose it could be a side lobe or another harmonic?
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Good morning, I just checked all the frequencies and noticed changes in 2 frequencies 11996 H and 12073 H the signal has increased I think it is using the EMENA beam because it has increased more than 5db on the 2 frequencies.
Satfaca
Melmac (46N, 14.5E)
Melmac
So move from BADR-4 to BADR-8.:Y
No changes here on those frequencies still on Badr-4.
Ivan Semov
Ku-Band 2x205cmAl Parabola
C-Band 2x305cm MZT Parabola
Octagon SF8008
Veliko Tarnovo,Bulgaria
11350 H 27500 Rotana mux
10930 V 30000 Test Signal
No signal in Bulgaria 200cm Aluminium Parabola
Satfaca
Melmac (46N, 14.5E)
Melmac
ocean04
Vaasa
10930V 7.0db and 11350H no lock.
11996H and 12073H slightly lower than before. And these are now EMENA BSS
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
I can confirm
I can confirm that. At least 11996 H is stronger 1-1.3 db then before...
